What HR cam with this set up
I'm honestly trying to run 11's. I'll probably only get a high 11 cause i'm staying with stock bore and stroke, i'm not sure
Have a 350 all cleaned up
195cc Afr heads
probably run a Rpm air-gap intake with a 750 carb. Not so sure on the intake yet. I'm still deciding. But the air-gaps are pretty good.
Going to be all motor backed with a t56.
Going to run hooker super comp shorties with more then likely a hooker cat back.
Posi 3:42 rear, may go 3:73's later on to see how much it improves.
I was going to run the EX282hr cam from comp with a rev kit, but many have said it wont get me 11's.
This will be daily driven/raced on some weekends when the weather gets warm again.
I'm not so sure on what cam to go with. I want hyd roller since its a daily driver and i want it to last.
195cc Afr heads
what about solid rollers? If my block was originally a hyd roller should I keep it that? If not then i heard solid rollers have better performance. WHat shoudl i go with hmm
I would stay with the hyd. roller, B/C with a solid roller, you have to adjust the Valve Lash a lot if you drive the car a good bit, it gets annoying popping the valve covers off all the time and adjusting.
