Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
400 Pontiac Engine
Old 01-11-2006, 06:58 PM
99TransAm666's Avatar
Default 400 Pontiac Engine
I just bought a $300 Camaro for my brother according to the old owner the motor is a 400 pontiac motor that he put in there. I was wondering if its a good motor. I was gonna rebuild it or was gonna swap for a 350. Is it worth rebuilding it or should I rebuild it.
Old 01-11-2006, 08:54 PM
GIZMO's Avatar
What are the casting numbers on the heads (two or three digits on the center exhaust ports)?
Old 01-11-2006, 08:55 PM
1CAMWNDR's Avatar
The 400 Pontiac can be a great motor. The cool thing is that Pontiac used one block for all of it's motors from 350-455 Can you say bore and stroke it ??
Old 01-11-2006, 09:21 PM
vodas00ss's Avatar
personally I think the stock 400 small block is a dog. I say change it up!
Old 01-12-2006, 07:19 AM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
400 is a great block to use. Post up the casting numbers so we can determine what it came from and so forth...
Derek
Old 01-12-2006, 09:54 AM
mikes98z's Avatar
400 chevy and 400 pontiac are good blocks....the only one I would stay away from is the 400 chevy 4-bolt main because the webing on the main cap area is very thin...these are prone to breaking under hi-po applications.
Old 01-14-2006, 06:43 PM
EPP
EPP's Avatar
Smile
The 400 Chevy engine is a small block, and a member of the 262/265/283/302/307/327/350/400 family. The 400 Pontiac engine is a big block, and is a member of the 287/326/350/389/400/421/428/455 family.
The Chevy 400 looks pretty much like any other small block Chevy, and the Pontiac 400 looks like any other Pontiac big block. I have owned and raced with both 400 small block Chevies, and 400 big block Pontiacs, and both can be built into real powerhouses.
If you have a 400 Pontiac, I wouldn't consider swapping it out unless you have a lot of Chevy parts laying around. I use to race with a 400 Pontiac that I had built up. I shifted at 6500 rpm every shift and raced the car sometimes at two to three tracks a week, for three years, and never hurt a part. Bob
Old 01-17-2006, 10:03 AM
Strokinit383's Avatar
You might want to check the casting number and find the application. I know the stock heads on some of those really sucked.
Old 01-19-2006, 03:54 PM
azzsmasher69's Avatar
dump the pontiac and build a 350 chevy.its alot cheaper.just built a pontiac motor for my buddys 77 trans am and it was a pricey pain in the a$$ to complete and still isnt running yet due to lack of funds.but on the other side i built a 355 for my 85 camaro no problems that ran 11.80s and didnt spend more than 4000 grand on motor tranny and car,trans am will probably see low 13 high 12s and hes already at around $5000 and still not done yet.but its your stuff, your money,do what you want.
Old 01-20-2006, 12:16 AM
TransAm12sec's Avatar
Isn't big block a term to distinguish only chevy motors?
Old 01-20-2006, 01:52 AM
steveo346's Avatar
umm no...thats kind of funny ...i could distinguish a big block from a small block in middle school...anyways i personally have a 71 formula firebird with a pontiac 400 its a strong motor and would recommend you sell it to a pontiac guy and but a chevy engine for the camaro....but other than that it is a good engine to mod
Old 01-20-2006, 06:45 AM
vr1967's Avatar
The Ponchos were always classed as Large Journal and small journal due to the cranks. The 326-400 were SJ where the 421-455 were LJ. They weren't classed as big and small blocks due to they being all the same dimenionally until the 301 came out in 79.
Also, Chevy sometimes marketed the 402BBC as a 400 in the "Big Car" (Impalas, Caprices, etc.)
Virgil
Quick Reply: 400 Pontiac Engine
