HP estrimate
HP estrimate
Got a friend putting together a big block chevy. What's your estimate on power? 454 but stroked to a 427, stock oval port heads 1969 396 with 101CC chambers, domed pistons( so I would guess at least 10-1 compression), .700" lift roller cam, single plain high RPM intake. It's just bolted together- no balancing or blue printing or even degreeing the cam. Also he is using a stock fuel pump and fuel lines. I can't see this combo producing lots of power but I am not really a big block chevy guy- to me it looks like the heads will limit HP and give it areally peaky power range.
I was thinking the high RPM stuff will make it a dog until 5,000 or so then the heads and fuel pump will choke it at about 5,500. I think he would be darn happy to make 550HP. Thanks!
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
850 hp? doubt it, the stock pump won't come close to supporting that kind of figure. Better heads is the first place I'd look, then a decent fuel system.
Derek
Derek
Easy 550 hp, definitely 600 if he sets it up right. That 12:1 is gonna want a lot of spark and a helluva lot of octane. What do you mean by stock fuel system though. That's gonna be one of the big limitations along with the heads.
I've got a 496 with a cam not much smaller than his. I kept it small for street use, although it's a solid roller. Aluminum Dart heads, Weiand intake, 950 Holley, Aeromotive fuel system...The motor is about 10.2:1.
The car made 463hp/588tq to the rear wheels on 93 octane. The cam is really holding it back, but I kept it small because I like to drive it. His compression will help make power, but have him pick a good cam and fuel system.
