2002-up 496/8.1L BBC info please
Does any previous years intake and heads fit these? or are they all by themselves. If so,what year/gen fits this block and heads. Also what about cams,standard OEM roller?
Thanks for any info.
8.1 liter
I have a 8.1L for sale. It was pulled out of a truck with 90,000 mile son it. It has a piston pin(it sounds like) making noise and the owners didn't want to take a chance on it( it had good oil psi). We put a low mileage motor in his truck for him. The motor is complete from intake-pan. I can send you some pics if you want. Will make a good deal on it. The block I believe it is like a Gen 6 BBC, taller lifter bores,timing cover and coolant holes(heads also) on the deck is different than a normal BBC. I also have the ecm for it..but the harness has been cut up, so you would need a harness.
email me jp85iroc@***.net
Thanks
Thanks
Do they share the same OE rollers as previous years? What about exh port spacing,are they the same as other BBC's to use aftrmkt headers? Would a late bbc head physically bolt on as far as coolant passages and head bolt alignment,and use an aftermaket intake?
Thanks for all the info.
496
This is the first 8.1 that I have seen..Hell I didn't even look at the intake to see that it does have symetrical port heads..but it does). Not sure on the other questions..I have a friend that is the part guy at the local chevy dealership..I will ask him tomorrow. The exhaust pattern looks the same.
later
later
Originally Posted by 93Polo
Does the 8.1 have a reluctor wheel like the LSx motors. Where does the factory computer get the signal for the coil packs?
8.1
yes it is. We put a used motor(out of a RV) that had 4,000 miles on it. They are the ones that cut the harness on the used motor. We just took the used motor and swapped the harness and coolant by pass from the rv to the 1 ton.
