Help decoding block numbers on 1969 small block
The casting number is 3932386 which I have found to mean it could be a 302,327, or 350. I want to narrow it down further from the stamped numbers on the front of the block- 19DO23798 and V11O4FB. Thanks!
Maybe the 302, 327, and 350 block are all the same since they use a 4" bore. I think in '67 all 327s switched to large 350 size journals, so I wouldn't be suprised if the blocks are identical.
