Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
18* head flow numbers inside = )
Old 03-11-2006, 09:04 PM
topend's Avatar
Default 18* head flow numbers inside = )
well finally i have heads that flow great.
Brodix 18c
Lift intake and exhaust at 28" drop
.100 64.6
.200 129.4 128.2
.300 198.1 191.4
.400 262.0 232.5
.500 314.3 252.0
.600 347.9 262.2
.700 373.9 267.2
.800 378.3 270.0
.850 378.7 270.2
Im very happy with the results.The heads flowed within 2% of advertised. The exhaust outflowed my brodix 10x unported on the Intake side lol.
the only thing i have left to do is pick a cam.Im thinking of going with cam motion.What cam and/or cam company do u guys recommend???(anything but comp cams)
Old 03-11-2006, 09:42 PM
LS1SSII's Avatar
I have had Cam Motion grind me three cams and they are all great. I will only use them.
Are your heads CNC spread port?
Old 03-11-2006, 09:54 PM
topend's Avatar
yes they are cnc`d
Check out the pics here
18* topend
Old 03-12-2006, 11:22 AM
PRAY HRD's Avatar
looks like some good #'s. how much lift are you actually looking at making? and what's the setup, turbo or s/c?
Old 03-12-2006, 01:13 PM
topend's Avatar
the cam numbers i dont know yet. i faxed my setup to cam motion. i`ll post on what they recommend.The shaft roller rockers have a 1.7 in and 1.6 ex.
Im going NA with my motor, nitrous maybe later.compression should be in the 14+ to 1 range.Flat top pistons netted 13 to 1 .
Old 03-12-2006, 03:35 PM
PRAY HRD's Avatar
oh, ok. i didn't realize this was a race application. so what kind of car?
Old 03-13-2006, 12:01 AM
93LT1's Avatar
do they make heads for a LT1??
Old 03-13-2006, 06:48 PM
slow trap's Avatar
i'll take a stab at the cam size not knowing how many cubes you're running=276 @.050 intake,284 @.050 exhaust,.710-740 lift with your rockers.
Old 03-13-2006, 06:56 PM
topend's Avatar
89 Trans Am
the motor is a dart block 4.185 bore by 3.875 stroke =426". The heads were flowed on a 4.155 bore so flow should pick up with my bore.I dont think your to far off with your cam recommendation .
Old 05-21-2006, 09:47 AM
topend's Avatar
Here`s my cam specs to my daily driver
Intake Exhaust
Duration 282 288.5 @ .050
Lift .782 .714
Lobe separation 109.9
Old 05-21-2006, 11:36 AM
TwoFast4Lv's Avatar
Nice numbers! I will probably be selling my Brobix 18* heads to pick up a set of CFE 18* heads.
To use them on a LT1 they need to be converted. I will be using mine on a LT1 I already have a Hogans Intake ready to do go.
I also order all the company cams through Cam Motion I try to keep lift in the low to Mid .600s so valve guide wear is not an isuue for a street car
BTW what CC's are the intake ports and the chambers?
Old 05-21-2006, 12:24 PM
topend's Avatar
If u put those heads and intake on your LT1 could u still call it a LT1???
I should of gone with a Hogans manifold too but at the time i was tossing the idea of going with a carb or fuel injection. So undecided i went with a regular intake manifold instead.
the chamber is 53cc and the port is 280 cc
Old 05-21-2006, 12:40 PM
TwoFast4Lv's Avatar
LOL the arguement of the decade! I still have an LT1 block and it is reverse flow and it is an Expensive PITA to get done. Sounds like a LT1 to me!
I sold a Complete LT4 top end to get the intake alone. I was thinking of going 23* RR but figured WTF if I am going to do lets do it all the way I have most of what I need. I had planned on just getting this set of heads finished but for the price I might as well just buy another set finished and be done with it.
here are a few pics
http://groups.msn.com/WashingtonFBod...to&PhotoID=519
http://groups.msn.com/WashingtonFBod...to&PhotoID=518
http://groups.msn.com/WashingtonFBod...to&PhotoID=517
http://groups.msn.com/WashingtonFBod...to&PhotoID=520
http://groups.msn.com/WashingtonFBod...to&PhotoID=530
http://groups.msn.com/WashingtonFBod...to&PhotoID=531
http://groups.msn.com/WashingtonFBod...to&PhotoID=521
http://groups.msn.com/WashingtonFBod...to&PhotoID=522
http://groups.msn.com/WashingtonFBod...to&PhotoID=529
Keep us up to date on you project!
BTW what car is it going in?
Old 05-21-2006, 01:13 PM
topend's Avatar
thats a nice intake manifold u have there.
My car is 89 GTA .
Quick Reply: 18* head flow numbers inside = )
