Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Need Oil Pan Advise for SBC in a 94 Camaro
Old 03-14-2006, 06:01 PM
it is on low boost
Nick K's Avatar
Default Need Oil Pan Advise for SBC in a 94 Camaro
I have a BMR K-Member and a Bowtie SBC that needs an oil pan. The thing is that I am going with the Headers from Lemmons and I don't want to order a pan that will not fit with the headers. My question is..What do I need to do or is there a combo that you guys know about? Heads are 18* High Port Bowties which require 2" stepped to 2-1/8" headers.
Any info would be appreciated.
Old 03-15-2006, 07:02 AM
cwaldt's Avatar
I'm running a stock oil pan on my 454 BBC and with a stock k-member and Hooker Headers 2455. The primaries are 2". I didn't have any problem with the oil pan hitting the headers. So I don't think you will have one if you go with a stock style SBC oil pan. I know that you may want to go aftermarket with more capacity but in my setup I was limited as to what I could do. Hope this helps some.
Old 03-16-2006, 07:42 AM
PRAY HRD's Avatar
those heads "require" that big of a primary tube? what are your plans with the motor/car? i know mine does just fine with 1 7/8" primary tubes on my 427"/Dart 18* high port head setup. and a guy with the same 427"/Dart 18* H/P heads in a twin turbo setup made 1200fwhp on pump gas with 1 7/8" primaries. the car has since gone on to get bigger turbo's and other mods, but uses the same headers yet and has gone 7.30's at 185mph in a full body car! so i'm just curious about why that size primaries are needed.
Old 03-16-2006, 10:53 AM
it is on low boost
Nick K's Avatar
I have been told by the engine builder that the primaries need to be 2" but everyone has their own recipe. I don't know exactly what is "needed", I am just going by what I have been told. It might be that all I need is 1-7/8" primaries...406" SBC Nitrous motor with capabilities of 600HP shot of nitrous and spinning at approx. 8900RPM.
Old 03-16-2006, 12:53 PM
orange88's Avatar
call Canton and see what they say
Old 03-16-2006, 04:36 PM
LS1Tech Sponsor
MADMAN's Avatar
I used Cantons pan on my sbc. It was a 15* 427 and I built my own headers that were 2" to 2 1/8 step. The only problem was the kickout caused me to have to drop 6 & 8 tubes to drop the starter. The pan I used was a 13-108
__________________
www.madmanandcoracing.com
225-343-9029
Old 03-17-2006, 06:54 AM
PRAY HRD's Avatar
a 600 shot?!?!?! Holy Crap!!! AND 8900 rpm?!?!?! damn dude, that's a bad sob you got there! go for the 2" stepped primaries then.
