carb'd sbc... retaining gauges/windows/etc
just as the topic says, when i do finally get a carb'd sbc(or bbc if i'm feeling that ambitious) how can i keep my factory cluster, headlights, windows, radio, key fob, etc working? Do i pretty much need to cut and solder every damn wire in the car?
Can any of the tuners(pcmforless, madz28, etc) Just delete the engine/tranny controls and parameters out of the pcm?
sorry if this has been answered, but i searched everywhere and couldn't find an answer and i'm dying to know.
thanks
thanks
As far as the headlights, windows, radio, etc. go, they should be on a separate configuration all together. But, when it comes to getting your factory guages to work, I think you might be out of luck.
Actually, retaining the stock gauges is quite simple.
Tach - youll need the instrument cluster from a z, but just hook the white tach wire up to your coil.
Speedo - i kept my stock computer so that my speedo would work (6 speed), but dakota digital makes a buffer box, or you can get one out of an older truck (i think it was prostreetz28 who did that)
fuel - untouched
voltmeter - untouched
oil pressure - i just got an adapter from ACE hardware to plumb my stock oil pressure sensor into the top of my intake manifold, if you have a one piece rear main block, you can also utilize the low oil light
water temp - will work with sensor in side of cylinder head
Am i missing anything? Its actually very straight forward and very simple.
fuel - untouched
awesome... thanks a lot guys. It's a long ways away because i'm going to UTI which is costing me $$$ and i don't make too much at my job, but i'm definitely going to get the ball rolling on a small block buildup soon. Any more advice/tips/experiences you guys have would be greatly appreciated
