Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
big block into 96 camaro
Old 05-06-2006, 06:09 PM
Thunder175's Avatar
Currently building a BBC 4th Gen car... browse this forum for answers to more of your questions.
Old 05-07-2006, 09:38 AM
Nate81Camaro's Avatar
yummy!
Old 05-08-2006, 01:28 AM
TwoFast4Lv's Avatar
VERY NICE!
BTW BMR sells a very nice K-member for the job
Old 05-08-2006, 03:37 PM
JPMuscle's Avatar
Originally Posted by TwoFast4Lv
VERY NICE!
The BMR is a nice piece but its also 500 bucks, PA racing version is only 298 plus mounts. UMI is suppose to be coming out with a Beefy as version sometime this month but i dont believe prices have been released.
http://paracing.com/product_info.php...fcdb8eec3a5741
-john
Old 05-08-2006, 05:44 PM
TwoFast4Lv's Avatar
I have a PA on My car Also I just remember the BMR having a slight better mounting system IMHO
Either or will work fine
Old 05-08-2006, 06:13 PM
Thunder175's Avatar
All this talk about K-members... Picture taken a little early on in the project
Old 05-09-2006, 01:42 AM
TwoFast4Lv's Avatar
looks like it is setup for motor plates?
Old 05-09-2006, 04:57 AM
Thunder175's Avatar
Thats correct. Front and mid plate for a very big BBC. Will probably be holding a 582 from Bischoff. Car is being set up to run 8.50's
Old 05-09-2006, 08:58 AM
fubar569's Avatar
simply badass! - I'm in the middle of a 427BBC swap in my 84 Corvette. it's always nice to see someone come into the light. there simply is no substitute for cubic inches! good luck to everyone and when we get these all finished up we'll have to meet up someplace and shoot the ****!
Old 05-09-2006, 10:22 AM
GTFORMULA's Avatar
Does anyone have pics of the 2455 hooker headers installed in a big block 4th gen f-body ? Is the a bigger primary header available that would fit? I was kicking around the idea of this for awhile and if other have done it and could point me in the right direction Id appreciate it. I was going to use a front motor plat and a poly mount of the trans. Is that ok ? What kind of things would you hane to do the get the distributer in and carb to clear the firewall ?
Old 05-09-2006, 10:32 AM
Slow Z28's Avatar
big block eye candy from my chassis guy. this is not my car, but a buddy Paul's car. He had gone 10.80's on a completely stock ls1 with a dual stage and TH400. now on to this thing
before pic..
chassis guy is the same guy who did the Impala on the Summit Racing Cover...
Old 05-09-2006, 10:44 AM
  #32
Thunder175's Avatar
You will definately need to cut the cowl either in the center. On my car I had it cut all the way back to where the windshield will be riveted and you'd be surprised how much more room you have to work with. With this method however it will require some tin work to close up the cowl again.
You will also most likely need to go with a crank trigger ignition. I cant see even with the cut cowl how to easily get back there to do anything back there. From day one I have been planning on running an MSD crank trigger.
Old 05-09-2006, 10:47 AM
  #33
Thunder175's Avatar
Slow, nice pictures thanks! Interesting how he replaced the firewall like that. I never really considered that because of the rules that change when you modify the firewall and/or floorboards like that.
Old 05-09-2006, 12:25 PM
  #34
Slow Z28's Avatar
No prob... the car is all tubular from the front subframe back. full interior will be tinned. full 4-link setup, etc... not going for any class, just fun. motor did like 1100 on the engine dyno. has a fogger ready to be tossed into the mix as well.
he modified the firewall so he could set the big block back a little further. has a TON of room up front now for the accessories. it's a pretty "raw" photograph but will obviously look better when everything gets painted and finished. the car has the mike moran hood, so because of hos big that is, that is why he cut up into the window like that. it's getting the percy's speed glass up front.
Old 05-09-2006, 12:54 PM
  #35
GTFORMULA's Avatar
Very nice pics. Thanks for the crank trigger idea. That may be the way to go. Anymore ideas on the headers. How high of a hood would you need with the big block. I know it depends on the setup but any rough ideas with a standard deck and victor with dominator.
Old 05-09-2006, 03:03 PM
  #36
cwaldt's Avatar
I'm running the distributer in its normal place and I have enough clearance back at the firewall to clear it. I also cut out enough on the cowl to where I can take the dist. out with the motor still in the car. Believe it or not. It actually surprized me that I'm able to do this. All this can be done and I'v still got my windsheild wipers. I'll have to get some up dated photo's. Here's some that are a month or so old. I don't have any pictures with the cap, headers, carb on yet.
http://www.porteighty.biz/uploads/incar1.jpg
http://www.porteighty.biz/uploads/incar2.jpg
http://www.porteighty.biz/uploads/incar3.jpg
http://www.porteighty.biz/uploads/incar4.jpg
http://www.porteighty.biz/uploads/incar5.jpg
http://www.porteighty.biz/uploads/top view.jpg
Old 05-09-2006, 05:47 PM
  #37
ball597's Avatar
the biggest problem i had with the2455 headers was on the pass. side firewall where the heater box used to be i had to massage it pretty hard to get the headers to fit
cwaldt did you have the same problem???
Old 05-09-2006, 05:54 PM
  #38
GTFORMULA's Avatar
Are there any bolt in headers for big block to f-body with big primaries. Also is there any oil pan problems with the kmember. How much room is in the front of the motor with it in the stock location.
Old 05-09-2006, 06:10 PM
  #39
ball597's Avatar
2455's will bolt in with some massaging..they are also 2 inch primaries
Old 05-09-2006, 06:28 PM
  #40
Thunder175's Avatar
Everyone has always said that they require "massaging", well what exactly does that mean and where does it need to be modified? Are we talking modifiing the flange or what?
Quick Reply: big block into 96 camaro
