305 whats the rpm limit
I was driving on the highway and a C5 Z06 wanted to race. At the end I was pushing slightly past 5,500rpm. The guages bounce a lot at that speed so I don't know exactly how fast or what rpm it was. But I'm not sure I have a limiter in the car. What would the max rpm you can take a stock 305 TPI too.
Unless you have a rev limiter (MSD 6AL - I've included a pic) in that car, no you wouldn't have a limiter in the car....
I googled it, but can't find anything.....I will agree w/ slow trap in what he said though....
Its a 86. Stock distributor and coil. Yea I can tell the power srops off pretty severe but with a light car its not that bad. The worst part is the gearing. Its totally mis matched for that engine. 5 speed. First gear is useless it will shatter if i use it on full throttle. So I end up with a 4 speed that maxes out at about 125-130.
Will that new ignition make any diffence in power or just give me a revlimiter.
I used to have a 035 TPI in my 91 Camaro and a 5 speed same as yours. If you have a stock cam and the red line is at 5 then dont go bast 5,500...maybe even before it, cus after that its been my experience that your not making power, just over reving. But a stock 350 TPI cam will give you another 500 on the red, which was an option (G92 I believe). Other than that just stick to bolt ons, and if you really want a rev limiter, which i dont think you need unless your not that good at controlling stick, then get that MSD above, its good **** for like $350 or so.
