Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
BB 496 progress.
Old 11-18-2006, 01:37 PM
smokin2002's Avatar
Default BB 496 progress.
well after 2 and a half months i finaly got my block back from the machine shop anyway friday i got my bottom end together and today i still felt ambitous so i went ahead and set the short block and trans together so i can weld in my plates. took a few pics for motavation when i heve it pulled back out. I actulal had no problem getting the whole works to go through the hood useing a cherry picker. im sure with the heads intake and distributor wont be so easy. took about ten mins to have it bolted up though
enjoy, im off to pull it all back out.
Old 11-18-2006, 02:09 PM
GOaT Cheese's Avatar
Very nice...I like it!
Old 11-18-2006, 11:56 PM
JPMuscle's Avatar
what are the specs on the rest of the motor, heads etc. How about the whole car?
Very nice tho,
-john
Old 11-19-2006, 06:29 AM
smokin2002's Avatar
Old 11-19-2006, 05:39 PM
JPMuscle's Avatar
nice, what kinda numbers are you looking for out of the BB2 heads?
-john
Old 11-19-2006, 06:51 PM
smokin2002's Avatar
I have no clue... Ive searched high and low for dyno numbers on 496's... ive seen pump gas motors claiming 600-750hp and race gas going 650-850hp. no one mentions at the crank or wheels.. This is my first built big block so id be happy just to see 600hp with that huge torque at a lower rpm. I probaly wont get dyno numbers at the crank, but id like to put it on a chasis dyno when its done. If it goes well ill put a direct port on top of everything just for reassurance This is all comeing from the car being high 11's with the ls1. so any ten sec time slip make me happy.
Old 11-19-2006, 10:13 PM
ulakovic22's Avatar
If everything is good, I bet you can see about 750 at the crank, probably more if everything is just right. Those are good heads and you're running high enough compression you should see good numbers.
Old 11-19-2006, 11:20 PM
TimTaylor75's Avatar
Very nice. Which K-Member are you using?
Old 11-20-2006, 03:56 AM
smokin2002's Avatar
Its the BMR setup for big blocks with the pinto style manual rack. I bought a flamimg river pinto rack. it took some custom made parts and fabrication to make it work. for anyone considering it keep in mind its not a direct bolt in.. youll need to make or buy tie rod adaptors/extensions, a clamp for the pass side of rack and a steering coupler adaptor 26 spline - 3/4''. Im not sure you can buy the way to adapt, the pinto rack has a smaller sae fine thread where the f-body balljoint is a bigger metric fine thread. and you need about 4 inches on each side.
Old 11-20-2006, 06:32 AM
cwaldt's Avatar
Looking good.
Old 11-20-2006, 11:20 AM
ulakovic22's Avatar
What Moroso pan are you running and also what headers are you going with that will clear a 7 qt. pan?
Old 11-20-2006, 04:35 PM
smokin2002's Avatar
I also found out if you plan on running the motor plates like i am the driver side plate will run right into your abs block and bracket. I found that the front sway bar mounting bolts in the frame rail match the front 2 bracket holes and you can move it up out of the way by bolting it there. just cut the tab off the bracket and you only get the 2 bolts in instead of 4... boo..
only one brake line needs to be bent to have it mounted there. works fine for me and the plate will not disturb anything.
Old 11-20-2006, 04:45 PM
smokin2002's Avatar
http://www.jegs.com/webapp/wcs/store...20057_-1_10457
Link to oil pan. 6 quart low profile
Old 11-20-2006, 05:05 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Sweet! What year car is this going into? 2002 by your name is my guess.
Old 11-21-2006, 12:27 AM
Thanks for the info in this thread. Good details along with some nice pics. Looks like you have good k-member clearance with that oil pan. Good luck with everything coming.
Old 11-21-2006, 06:38 AM
cwaldt's Avatar
Heres my solution to the ABS block and motor plates. I'm not running a plate but I wanted to move my ABS block to free up more room. You can see it that great but you can see that its been moved to where the ram air box used to sit.
Heres the clearance I got out of my Hooker Headers 2455 on the passenger side. I'm not through with the drivers side yet.
Old 11-21-2006, 03:46 PM
smokin2002's Avatar
Yes the car is a 2002 ws6.. If we only know what we are going to do with a car the day we buy it!! heres what it looks like, i did take off the rear window shade and it has the 8 point cage in it now
Ill get as much info as i can throw up as it comes. deff some vids when up and running.
Im kicking myself now because i forgot to take a driveshaft measurement when everything was set and mounted
Old 11-21-2006, 04:03 PM
smokin2002's Avatar
Heres the interior put back together with the cage, along with my my new dash layout at night time
Old 11-21-2006, 04:07 PM
ulakovic22's Avatar
That dash looks awesome. I thought about doing that, but since I don't have A/C I'm just going to use the vents for gauges and run the 3 3/8 tach & speedo with the rest being 2 5/8 gauges. One in each corner and one in the middle between the tach and speedo, then the rest in the vents.
Old 11-21-2006, 11:16 PM
Looks great. If you get a chance, could you get some day-time pics of your gauge setup? Thanks.
Quick Reply: BB 496 progress.
