BBC Clearance Question - LS1TECH
Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Thread Tools Search this Thread
Old 04-14-2007, 09:14 PM   #1
evojuiced's Avatar
Default BBC Clearance Question
Can someone measure the distance between the frame rail and the exhaust port on their 454 4th gen swap.
also from the valve cover to the shock tower.
How close does the steering shaft come to the head?
evojuiced is offline   Reply With Quote
Old 04-15-2007, 08:34 AM   #2
itll fit. just need custom header work for the steering knuckle. you can set a complete motor less carb dist cap and headers straight thru the hood
smokin2002 is offline   Reply With Quote
Old 04-15-2007, 01:25 PM   #3
evojuiced's Avatar
i know it will fit, i'm trying to see if their is any way to make a set of forward facing turbo headers that will clear the shock towers.
Old 04-15-2007, 02:04 PM   #4
You can do it but the turbo's will have to be mounted a little low. You can't come over the top like with an SBC.
ulakovic22 is offline   Reply With Quote
Old 04-15-2007, 02:09 PM   #5
evojuiced's Avatar
it will be running a large singe in the front bumper area.
Old 04-16-2007, 09:46 AM   #6
Front and center or off to one side with an intercooler or what? Doesn't sound like it will be a problem then.
Old 04-16-2007, 10:17 AM   #7
evojuiced's Avatar
front and center with the IC in the cab, Only problem is i also have to fit a 5" DP
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
