What kinda HP should this setup make?
388 stroker
Eagle crank & rods. .60 Over
Keith Black Pistons 10.5 -1 comp. MSD Dist
Roller Rockers, Wieand Intake. Holly Carb,
400 heads with 1.94 1.60 valves, ARP Bolts
COMP CAMS CAM Specs Below
Basic Operating RPM Range: 2,500-6,500
Advertised Duration: 292 int./292 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.501 int./0.501 exh. lift
Lobe Separation (degrees): 110
Grind Number: CS 292H-10
@ flywheel?
@ flywheel?
depends on what CC the heads you have on there, but you could pick up some vortec heads cheap <600 but they have 64 CC chambers so it depends how your compression would sit afterwords
there are tons of better flowing aftermarket head for a lot more money though
Depends on what "cheap" is to you I guess. A set of budget vortec heads would really wake that motor up and push you well past 400hp.....BUT---Most of the 400 heads had 76cc chambers IIRC. If you're already at 10.5:1 static compression with them, your compression would shoot into race gas territory with vortec heads since they're 64cc. Define "cheap" and you'll get some suggestions on what you can afford.
