Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
help me make a killer 383 combo
Old 04-02-2008, 09:01 AM
proxemics's Avatar
Default help me make a killer 383 combo
hi guys
I sold my intake (RPM air gap), carb (holley 750dp) and cam ( lunati flat tapp)
what I have now:
383 short block with scat forged crank and rod
lunati doomed pistons
dart pro 1 aluminum heads 200CC
12:1 compression
1.6 rocker arms
comp cam double roller timing chain
millen hi volume oil pump
morose oil pan
electric water pump
msd ignition system
headman long tube headers
can you give me an idea about what should I get to make this 500+hp engine
I'm thinking about getting super victor intake and quick fuel 850 carb I want a solid roller cam but I don't know what cam will work best for me.
this engine will be drag race only and I will use 150hp shot
any idea will be highly appreciated
Old 04-03-2008, 07:23 PM
moge11's Avatar
Get the heads Ported and a super vic, quick fuel 850, and a 255+ @.050" duration and 630"+ lift. If the heads are Ported to 300+cfm, which is easy out of those, then it oughtta make 600ish HP....Easy 575hp.
Old 04-04-2008, 06:02 AM
proxemics's Avatar
thanks man
Old 04-05-2008, 11:48 PM
1997bird's Avatar
253*/259* @.050" duration, 111*+5*, .640"/.640" lift w/1.6's
Old 04-06-2008, 04:18 AM
proxemics's Avatar
thanks man
what size headers should I use I Believe mine is 1 5/8 is it fine?
Old 04-06-2008, 02:11 PM
1997bird's Avatar
Originally Posted by proxemics
thanks man
I would run 1 3/4" primary headers.
Old 04-07-2008, 03:05 AM
proxemics's Avatar
That's what I thought
thanks
Old 04-07-2008, 03:34 AM
JUICED96Z's Avatar
What hood do you have on your camaro????
Don't go to big on the headers of it will kill you at the track, I have a 468 and don't have big headers.
If its race only I would crank up the compression some more and jump the nitrous up, for that bottom end it may not be the best but I bet it will handle more bottle
Old 04-07-2008, 08:53 PM
F-Body Lover's Avatar
hey bro Im from Bahrain u got a nice set up there hope to see u on BIC drag strip
btw Im selling my 1992 Z28 Anniversary Camaro if there is someone in KSA is searching for one
Good luck in ur project
Old 04-08-2008, 01:01 AM
1997bird's Avatar
I think it was Hot Rod that had an article a few years ago about header primary sizes with the same dyno motor. The 1 5/8" primary headers only out performed the 1 3/4" primary headers from 3,400 to 4,000 rpm, and even then it wasn't by much. The 1 1/2" primary headers actually out performed the 1 5/8" headers almost all the way across the rpm range. I still beleive that the 1 3/4" headers are the way to go.
Old 04-08-2008, 03:29 AM
proxemics's Avatar
The hood is made by local store
F-Body Lover:
sure man I'll try to make it to BIC drag strip
PM me with more info on your camaro
Quick Reply: help me make a killer 383 combo
