Who to screw the power stirring pump?
Hi,
I bought an disassembled Impala (350 cui, 1970), therefore I have some problems to put it together.
Right now I struggle withe the power stirring pump.
I put the bolt through the water pump hole (see pic)
http://i303.photobucket.com/albums/n...rstirring3.jpg
But where do I have to fix the following part (pics) to adjust the belt at the engine?
http://i303.photobucket.com/albums/n...rstirring2.jpg
http://i303.photobucket.com/albums/n...rstirring1.jpg
Do have to fix it with a bolt of the exhaust manifold, and where else?
Thanks for help.
James
Thanks for help.
James
That looks like what I used to use. The bracket bolts to the front exhaust manifold bolt, the welded nut on it should go to the power steering pump bracket with the slot.
If you use headers you need to use a spacer on the exhaust.
But like this I fix the bolt close to the welded nut, but where do I have to fix the second screw for the second hole on the other site?
