sbc in a 4th gen no computer will the vats still work?
I took out the computer out of my car when I put in the new engine. Last time I left the computer in it and it started right up(gen 1 sbc) Now that theres no computer it wont turn over and the fuel pump isnt turning on either. Is this the vats not letting it start b/c of no computer?
Is there a way to still use the key to start it up and bypassing the vats?
I triedand but didnt really come up with anything like this.
Sounds like VATS, my last car did that when the cage got intalled and they forgot about the VATS and I pluged in the wiring and the car started.
There is a way to bypass it, its a bit of a pain, might search camaroz28.com, I think thats were I saw it.
If its carbed I am sure you could pull the VATS system all together and not worry about it but I would search camaroz, remember seeing some stuff on it there.
VATS has its own module below your steering column. Check the resistance on your key using a mulitmeter. Place a terminal on each side of the key's chip. Once you have the resistance go buy a resistor with the same resistance and splice it into the wires running to your vats module (small black box). I have a diagram i can post when i get home from work. Its really easy to do. I dont think your PCM would have anything to do with the VATS, but i could be wrong. Mine didnt.
Will these diagrams apply to the 3rd gen camaro as well? I ditched the OEM computer for a Holley Comander 950 Pro and have not yet fired the motor in the car. Might run into this problem as well.
