Best Set Up For Zz4
In-Zane Moderator
What kind of question are you asking? You have several fuel options here, you want race fuel? Pump gas? Ethanol? Alchohol? E85? There really is nothing special about a ZZ4 block, it is just another 4 bolt 350 really. Stroke it to 383 cubes and put whatever heads and cam you want on it to make the power you are comfortable with. Compression and other things depend on the fuel you want to use.
zz4
i was looking at the edelbrock packages i have a edelbrock carb and intake manifold so i wanted to just get the heads and cam but i cannot find them anywhere do they sell them seperatly
zz4
im not dead set on anything i just want a good cam to match good heads and the power pakages are perfectly matched i dont really understand hwo you match a cam to heads could you explain ?
In-Zane Moderator
You need to know what cubes can support what heads at whatever desired RPM, a high performance motor will usually have large heads and huge cam to match, a smaller street motor will have mild heads and cam, mid performance will be stepped up from stock bot nothing over board, a 350 with a 400 HP need will love vortecs and a mild cam, a person looking for 500 HP would look for 383 cubes and 200 cc heads with a cam about 240 duration or split 236/242. From there lift depends on the heads flow charicteristice, then there is the option of roller, flat tappet and then solid or hydrolic.
