Valve spring question
What springs would work well on http://www.competitionproducts.com/p...ber=RHS12410K1 that could handle .6 lift and not require much modification if any?
This spring is what you will need for your application. You don't have to run this brand of springs if you don't want to, but make sure your installed height is the same & the spring pressures are about the same. http://store.summitracing.com/partde...881+4294774833
