New motor sound clip - LS1TECH
Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Thread Tools Search this Thread
Old 06-04-2008, 04:59 PM   #1
In-Zane Moderator
ZONES89RS's Avatar
Default New motor sound clip
Well, it is done. I am happy with it with the exception of timing, i might not run a vacuum advance, it makes it detonate if i have the timing up where it likes it during normal operation. We will see.
Enjoy.
ZONES89RS is online now   Reply With Quote
Old 06-05-2008, 02:40 PM   #2
92builtbird's Avatar
sounds good zones!
92builtbird is offline   Reply With Quote
Old 06-05-2008, 03:36 PM   #3
very nice
drrobotnik is offline   Reply With Quote
Old 06-05-2008, 04:36 PM   #4
In-Zane Moderator
ZONES89RS's Avatar
Thanks fellas, the oil pressure was acting FUCKED today, i hope it is the gauge or line to it...
Old 06-05-2008, 09:51 PM   #5
1997bird's Avatar
What was your main bearing clearances? Rod bearing clearances? Side to side rod clearance?
1997bird is offline   Reply With Quote
Old 06-05-2008, 10:24 PM   #6
In-Zane Moderator
ZONES89RS's Avatar
Not much...
Old 06-05-2008, 10:33 PM   #7
1997bird's Avatar
Quote:
Originally Posted by ZONES89RS View Post
Not much...
So........you just slapped her together and fired her up, now she's trying to blow up.
Old 06-06-2008, 05:00 AM   #8
In-Zane Moderator
ZONES89RS's Avatar
I think from pilling the intake a couple of times something or things is pulled into the pickup.
Old 06-06-2008, 12:51 PM   #9
that sounds sick...do u have a glass pack on there or is it just straight exhaust pipe?
UpOnOne781 is offline   Reply With Quote
Old 06-06-2008, 08:07 PM   #10
In-Zane Moderator
ZONES89RS's Avatar
Straight pipe all the way out the back, it has a custom Y you can see under there to retain the dual exits.Glad you like it!
Old 06-12-2008, 01:07 AM   #11
In-Zane Moderator
ZONES89RS's Avatar
Well, there was RTV in the pickup, not tons of it but several small pieces. I hope that was the issue, i have the new pump in, pan back on and K member back up. Tomorrow ill button everything back together and see what happens.
Old 06-12-2008, 01:10 AM   #12
travie319's Avatar
Sounds good
travie319 is offline   Reply With Quote
Old 06-12-2008, 12:59 PM   #13
In-Zane Moderator
ZONES89RS's Avatar
Thanks, you should hear it in person.
Old 06-12-2008, 05:23 PM   #14
In-Zane Moderator
ZONES89RS's Avatar
Well, it still does it, even swapped the oil pressure gauge just in case. Not AS bad but still does it, i cranked the rev limiter up and ran it to 6600 RPM to see what would happen, nothing. So, i am just going to drive it till it blows up. F it.
Old 06-12-2008, 05:24 PM   #15
In-Zane Moderator
ZONES89RS's Avatar
If it blows up.
Old 06-13-2008, 05:55 AM   #16
1997bird's Avatar
Nice outlook on your new motor! How much oil pressure do you have at idle and with some rpm in her?
Old 06-13-2008, 03:42 PM   #17
In-Zane Moderator
ZONES89RS's Avatar
I am talking **** because i am just tired of messing with it, i just wanna drive it. But, it has 45 lbs at idle, at 2500 RPM it has 60-70, then any higher it starts falling off with the more RPM it gets.
Old 06-13-2008, 05:50 PM   #18
jmm98LS1's Avatar
If it gets worse as rpm increases, it sounds like you could be sucking the pan dry.......lemme guess---high volume oil pump & a 5qt pan?
jmm98LS1 is online now   Reply With Quote
Old 06-13-2008, 07:20 PM   #19
In-Zane Moderator
ZONES89RS's Avatar
Yea, but now it is a std volume pump and a 5 qt pan with an extra quart, this problem ocurred later on, not right away, it would have been from day one.
Old 06-13-2008, 09:31 PM   #20
82 camaro's Avatar
Do Not run extra oil in the pan... Stock pan try running 4.5 to 5 qt. of oil with a filter change. Did you check the oil pump pick up to pan clearance?
82 camaro is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
