Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
valve springs
Old 07-21-2008, 12:09 PM
monzter's Avatar
Default valve springs
i need valve spring that can handle about .700" lift and are o/d 1.460" in solid roller sbc
what do you genious reccomend.
Old 07-21-2008, 09:43 PM
MrOverkill's Avatar
Isky Tool Room or PSI are the only springs I'll buy.....
Old 07-22-2008, 11:48 AM
monzter's Avatar
where can i buy these psi springs
Old 07-26-2008, 09:13 PM
Kevin91Z's Avatar
That's a pretty small spring you're asking to get up to .700" lift. The smallest diameter Manley spring we have that will handle .700" lift is 1.550".
You can buy almost anything from Jegs or Summit. Try your local speed shop first, so we can keep them in business.
Old 07-28-2008, 09:56 AM
Ryan02SS's Avatar
Crane 99893-16 - Crane Cams Race Valve Springs Details
Double Valve Springs
1.460'' diameter double spring. Valve lift up to .690''. 120# @ 1.875'' closed, 426# @ 1.110'' open, coil bind @ 1.080''.
Old 07-28-2008, 11:21 AM
kenSS's Avatar
PAC makes small diamter springs with high pressure.
