update on my new motor
well i put the new converter in it which is a yank 3,600 and did a baseline dyno and it put down 380rwhp...... its a 388 stroker with dart pro 1s pnp and T350, with 12 bolt..... i know that tranny and rear end setup it gonna eat some extra power but i really thought it would have had over 400rwhp???? i know i know dont worry about the dyno and yes the car runs good but think if i can harness some extra power and put even more down???? plus i could have make that kinda power with a baby cam 350 with vortech heads i would say right?????
also my plugs look very black and had some fuel on them when i pulled them so i dropped the jets down 2 sizes front and back and it seemed to run a little better but is it possible that it messed the plugs up a little and i shoudl put some fresh ones after i get the fuel dialed in better????? also i run dual cutouts on it and they sound so bad i will never uncork them so i plan on removing them but i assume they create heavy turbulance when i run them that could effect power and air flow...... other than that i am happy with the car cause it out ran a 90mph 8th mile car buy 5+ cars before i hit 6,000rpms so i really cant complain but i wonder if i really have my fuel and timing way off???? timing is set at 36-37 degrees, fuel pressure at 7 with no regulator but i can install one if you think it will help,
6 & 8 Second Club
I can't remember last week, how the heck can an old guy like me remember 20 years ago.
I've been BBC's a long long time. At least I was the 1st to reply!!
thats ok man.... i knew the T350 and yank stal would eat a little more power but damn i figured i could atleast hit 400rwhp with a somewhat beefy cam, mech roller, vic jr ported intake, and ported dart heads!!!! i mean even with issues i thought it would make more power than that.... i just need to take it down the track and see what she does and then i will worry about it if it dont run well!!!
Timing and fuel pressure should be close.I run FR5 NGK plugs N/A on the street. Plugs should never be black though...Maybe check the idle for sure...start at 1.5 turns out on the needles? if it's a 750hp Holley carb, it will probably want 72-74 jets and a Powervalve up front and 82-84 in the rear and no powervalve(plugged). Not sure on air bleed sized, sorry!
well i have a basic holley 700cfm double pumper...... i hear that a 750cfm HP version carb would help me out.... also i dont run a fuel pressure regulator at all..... im just hoping that my plugs being so bad looking and having those nasty cutouts restricting my airflow was keeping me from that extra 20rwhp cause as long as i can atleast get 400 to the tires i will be content with me using the parts i used.... cause i didnt pick a sollid roller and have to adjust the rockers from time to time to get the same power i could have gotten had i used a hyro roller.... you feel me????? also i wonder if i was to get 400rwhp the next time i put it on the dyno ater i fix the issues i have what would my motor be pumping out at the flywheel????? seeing im running a T350, 3600 stall and 12 bolt?
another question to guys who know carbs..... before i put it on the dyno it was actually running fine but the plugs looked black so we dropped the jets down 2 sizes front and back and it seemed to run fine but ater i left the dyno on the way home and until now it stumbles down low until the back barrels kick in and then it cleans up and runs right..... it almost seems like its running too rich down low but i dropped 2 sizes???? and if it was too lean it would hick up when i hit the gas right????
also does anyone know what a holley 110 gph is capable of as far as hp rating???? i run a 110 with no regulator with fuel psi around 6.5 and it seems to be fine up top..... and does anyone know a place i can get on that specializes in SBC carb stuff cause this site leans tward LS1 of course..... i feel like if i get around enough sbc carb guys they might have been through some of my issues.... theres a few on here but 90% of LT1 LS1 which i can understand...... i am on LS1tech LOL
380rwhp in your 1st gen will fly....should go mid to low 11's no problem. Non lockup stalled cars throw down shittiy dyno numbers but kick *** were it really matters.....the track!!
yep your right about that...... this thing goes right to the power when i hit the gas.... the thing is my plugs are wet with blackish gas and crud on them so i know it probly has 20rwhp worth of power i dont have due to it being that much out of wack.....
i would deffinately run a regulator.... and then maybe jet it according to Autoroc....
by any chance you got any motor parts hanging around? I always ask
just wondering but why???? my pump a holley 110 puts out the perfect amount of fuel for my setup i would say around 6.5psi..... explain more if you still think a regulator would help me out
and yeah i got some new fuel pressure regulators, a fairly new billet specialties spark plug wire loom kinda thing that looks cool, sbc alternator and water pump that still work great and much life left, possibly a almost new holley 700cfm double pumper, maybe 300 miles on it, if you can weld a set of hedman headers that are coated for sbc camaro chevelle 1 3/4 but i had to dent them due to my steering setup and i cut out the area i had to bedn which was about 5 inches so if you took a pipe and had it fit and welded i will sell them CHEAP since i had to cut them.... they are NEW but installed and ran for about 20 minutes, also for 1998-2002 LS1 k&N filter charger open air filter setup!!!! and last but not least a 4 inch mufflex cat back...... i got some pretty neat things for sell i guess???? jake
ok guys check this **** out...... i mess with the jets around tonight for a lil while and figure out the car was running way lean..... it was making my plugs bad from having the wrong power valve in there but when i used a vaccume pump on paper it was right..... but in reality it was making my plugs look terribal and made me think it was running way to rich so i kept down sizing the jets....
so tonight i said screw it im gonna add like 4 jet sizes to it and see what happens and the car woke up like crazy..... no stumbling or studdering through the medium rpm range just clean crisp running and then whe i hit the gas at anything under 50 mph the car murders the tires until i let out..... i dont know for sure until i get it back on the dyno and im gonna get these cut outs taken off and re weld some pipes in place but i can bet it picked up some serious power tonight..... so tomarrow im gonna put the right power valve in there, put some fresh clean spark plugs in there see if the jets need to be taken down or added one size and take it to the track..... its hard to say but i would bet that the car is well over the 400rwhp mark after giving it the fuel it wanted
6 & 8 Second Club
Spacers are a test & see item. It is impossible to guess.
I do always run a small wood spacer on every car to keep heat out of my carbs.
I would say start with a wood spacer & test, if it helps, add more. Good luck.
