Southern Members A regional forum for all our down South members.
wanna go in the 6's 1/8th mile!! jus learning about the ls1! advice please!!!
Old 06-25-2010, 04:03 AM
downSOUTH_TA's Avatar
Default wanna go in the 6's 1/8th mile!! jus learning about the ls1! advice please!!!
i have a 98 trans am!! nothin major done to the car.. has a mild shelf cam and springs. cant tell u nothin about the cam really like as far as specs im not mechanically inclined. it has a tci 3500 stall converter, long tube headers, slp exhaust, rwtd tuning.. stock gears. car runs real good but not what i thought it would do at the track. i want more out of it!!! would like to go in the 6's in the 1/8th.. im a young guy so dont wanna spend a fortune. would like some tips on what to do!! yall r the experts with this so plz help me out i would really appreciate it! thanks!
Old 06-25-2010, 09:59 AM
Travose21's Avatar
take that baby mild cam out and put a bigger one in there with some tsp 5.3 heads and 150 shot low 10's all day i did it
Old 06-25-2010, 10:01 AM
Travose21's Avatar
or use what you got and lighten ya car up alot. when i mean alot i mean alot
Old 06-25-2010, 10:45 AM
OUTLAWZ RACING's Avatar
Hows the suspension? and what tire do u run?
Old 06-25-2010, 11:02 AM
KH504's Avatar
100 shot would do it for you and be cheap.
Old 06-25-2010, 11:08 AM
nostixs's Avatar
ive got a built 370 shooting for mid 6's
Old 06-25-2010, 04:39 PM
i was running a small mickey thompson e t! and the suspension is stock!!! it hooked great!!! it has high gears in it too!! i was wonderin like a 3:73??? and wat nitrous kit what fuel pump? i dont know where to start!!! give me a list and ill go with that!!!!
Old 06-25-2010, 04:40 PM
hows the bottom end gonna hold up??
Old 06-25-2010, 05:13 PM
98z-28redcamaro's Avatar
these motors will handle alot.... just keep that oil level checked.... but a good set of tires and 3.73 gears and a stall will put u in mid/low 7's and a 100 shot will get u 6's easy
Old 06-25-2010, 05:29 PM
it has a tci 3500 stall in it!!! how much should gears cost me? parts n labor n wat kind? and whats the best nitrous kit? how about suspension man? and what size tires? i need to know everything!!
Old 06-25-2010, 09:42 PM
BlueThunder2's Avatar
3.73's with a T/A Girdle and install kit. A shop should charge you about $250-$300 to install. At least a 224/224 cam, at least an LS6 Intake, Ported stock throttle body, Headers, y-pipe, cat back exhaust or cut-out, NX or Nitrous Outlet plate kit with 150 shot and a good tune. Should be touching 6's. Change out the TCI converter and install a Yank 3600, and a set of aftermarket 5.3 heads, should run mid 6's. remove front sway bar, change out rear suspension, and add subframe connectors, put fats and skinnies on, should be in 6's all day.
If only running the 1/8th, you could use 4.10s and be even quicker in the 1/8th.
Hope this helps.
Old 06-26-2010, 05:08 AM
Hope this helps.
thank u so much thats what i been lookin for... im so glad i found this site!!!
Old 06-26-2010, 05:10 AM
Hope this helps.
question tho??? whats wrong with my tci converter? i mean could i get by with it for now!!! and will my rear end hold up with this power??
Old 06-26-2010, 09:30 AM
The TCI converter just isn't as efficient as the Yank. The two best companies to deal with for converters on LS cars are Yank and Vigilante (Precision Industries). The TCI will get you there, but you'll be missing out on some power available.
The rear end will eventually break. There is no telling how long it will last. I went through three rear ends very quickly before I finally stepped up to a 12 bolt. However, I know people who have been running with the 10 bolt for a few years hitting low 11's and high 10's in the 1/4 without problems. It will get you through for a while, but don't trust it.
Old 06-26-2010, 10:55 AM
yarrie's Avatar
i have a Performabuilt 3400-3600 stall and my best 60ft. was 1.54... it cut 1.60-1.61 all day in this 100+ weather
Old 06-26-2010, 01:55 PM
Performabuilts and TCIs are both good. All the converters will get you out of the hole well. The STR has everything to do with that. However, the more power you make, the harder it is to find a converter that is efficient on the top end. Smacking the rev limiter during shifts and on the top end is easy to do when you have a converter that doesn't hold up to the power, or isn't efficient on the top end. I've had and seen worn out converters cause low ten second cars to run high tens and even low elevens because they just couldn't handle the load. Typically, you will find the highest horse power and the quicker cars running Yank. Just my .02
Old 06-26-2010, 02:18 PM
lemons12's Avatar
Blue thunder has the only posts in this thread that have useful info in them without anything misleading. Only thing I would like to add is that PTC makes amazing converters.
I am not a huge follow of Yank myself. I prefer PTC/Vig/Yank, in that order... Everyone has their preference and their reasons why.
As for a quick way to get 6s.. You should be high 7s right now. A 150 hit should get you there solidly.
EDIT::: Didn't see all your mods. You only run an 8.2 right now, you have some work to do first.
Old 06-26-2010, 02:23 PM
lemons12's Avatar
Best advice for you OP... Start reading. Not just random *** threads like this with people that have never even made a mid 7 pass in the 1/8 or just have bolt on cars.
Go read the stickies.. If you run into something you are unsure of what they are talking about then go research that and come back to your research.
You read for a solid 2-3 hours for 7 days you will have a general idea of where you want to go. After that make a more solid post instead of "I'm completely lost and want to run 6s" with a general idea of where you want the car to go and how you want it to get there and with what budget. Post up in a section where the more advanced tech members post and see what ways they revise your plans.
You mod your car how someone else tells you to mod it I can almost guarantee you won't be happy with it. You might luck up and be happy with it for a while but 3 months down the road you will do some research and say, "DAMN IT, why didn't I go that route?"
Old 06-26-2010, 02:27 PM
madmike9396's Avatar
i would do full suspension then converter then add the Bottle
Old 06-26-2010, 03:18 PM
i get what u sayin lemons12 about readin up n i have been.. im knew to this site and wanted to ask a question... and i got what i needed. thanks everybody.. u will b seein me soon blue thunder!!! thanks Todd
Quick Reply: wanna go in the 6's 1/8th mile!! jus learning about the ls1! advice please!!!
