Special Edition Vehicles Firehawk | SS | WS6 | Berger | Blackbird | Comp T/A
93 Trans am Help/opinion (special edition redirect)
Old 03-23-2011, 02:27 PM
93TransAmCustom's Avatar
Default 93 Trans am Help/opinion (special edition redirect)
Exact of original post-they said id have better luck here
I have a question for all you experienced LT1 guys. I own a 93 Trans Am GT and i just received my build order from GM. Apparently it was a custom ordered one and i had some questions for you guys regarding it. the sheet says that i have an LT-1 H.O. an MN6 transmission and a GM performance diff. with 3.43's. it also says the 155mph was deleted, it was 334hp and 367fptq and that it has a 6qt gm performance intercooling oil system. has anyone ever heard of this? with the hp rating and everything? we're all these extras optional for the generation or is this a weird one?
Old 03-24-2011, 04:11 PM
Brangeta's Avatar
I'm a Camaro person, but can probably help you out anyway.
LT-1 normal
MN6 normal
performance diff = RPO codes were weird for '93, but should be G92 most likely. normal
155mph normal with RPO QLC tires
334 hp and 367 fptq isn't normal at all. Sounds like they maybe gave you the rating for a Firehawk?
Not sure about the oil system.
What's your VIN #? I can look into it and see if it has weird options.
