What size are the sway bars on the SS?
Moderator
I am getting Energy Suspention sway bar bushings. I think the SS is different from the Z28? What size are they? Front & rear?
Unless you have a 1LE package.
"This performance suspension system, now being offered exclusively by SLP, includes double adjustable Koni Shocks. (n/a on convertible or with Bilstein Suspension Package) 1LE suspension is back, and now offered exclusively by SLP. It includes Koni double adjustable front and rear shocks allowing you to "tune" your suspension to your specific handling needs. Front upper and lower control arms are tightened up with stiffer rubber bushings. Hollow 35mm front swaybar significantly reduces body roll. Includes revised endlinks, reinforced body mount brackets and firmer bushings. Rear lower control arms with firmer bushings reduce wheel hop under heavy acceleration. Larger 21mm rear swaybar and bushings decrease body roll. Package also includes Koni shock adjustment tool."
