Stainless Works "special request" S10 Header group buy!
Old 04-17-2013, 11:24 AM
  #201
Petraszewsky's Avatar
i thought you weren't getting any tiresmokin? I'm leaning towards having my set polished...definitely V bands installed
Petraszewsky is offline
Old 04-17-2013, 12:03 PM
  #202
tiresmokinV8's Avatar
After doing all that work to get the new engine mounts to work and since if i were to run my old mounts and lts id have to redo my trans mount because my old mounts set the engine up a solid inch higher, so i decided to get a set myself. Itll take me redoing the front half of my exhaust but everything else should be set so why not. Even though i still plan on going turbo in the future.
tiresmokinV8 is offline
Old 04-17-2013, 02:51 PM
  #203
StainlessWorks's Avatar
Looks like they fit!
Just figuring out exactly what mods are necessary around the control arms on the second truck.
WHO IS RUNNING STOCK CONTROL ARMS? WHO HAS TUBULAR?
StainlessWorks is offline
Old 04-17-2013, 03:24 PM
  #204
Awesome! So will there be 2 different sets depending on what control arms you have?
Old 04-17-2013, 03:28 PM
  #205
tefoster's Avatar
I have stock
tefoster is offline
Old 04-17-2013, 03:42 PM
  #206
artlsx10's Avatar
Tubular a arms here
artlsx10 is offline
Old 04-17-2013, 04:08 PM
  #207
383Nickles's Avatar
UB Machine tube uppers
383Nickles is offline
Old 04-18-2013, 06:04 AM
  #208
FYI mine has UMI so you know they should fit great around those!
Old 04-18-2013, 08:41 AM
  #209
TXMaro's Avatar
I'm stock at the moment.. If I have to go tubular to fit, I wouldn't be opposed to that.
TXMaro is offline
Old 04-18-2013, 09:19 AM
  #210
Will be using Tubular Arms
Old 04-18-2013, 12:58 PM
  #211
Just one set.
Stock control arms will need to be trimmed for proper fitment. There just isn't enough room in the bay for tubes that size and everything else.
Sounds like a lot of you already have tubular A arms so this ought to work out nicely.
-Jason
Old 04-19-2013, 02:13 PM
  #212
Should have headers in your hands in a month (plus or minus a week)!
I will send out emails and make phone calls in two weeks to everyone so they have a heads up.
-Jason
Old 04-20-2013, 06:52 AM
  #213
ZQV8's Avatar
I have tubular uppers, and also need my truck at a show in a month...
ZQV8 is offline
Old 04-22-2013, 06:54 AM
  #214
The order for the headers was just released to the shop.
Based on the bender's cycle and current lead times, we ought to have headers to you before the end of May. I know its a wait but these things are gorgeous.
I will be contacting everyone in the next two weeks or so to confirm payment methods and any add ons (like V bands).
HOME STRETCH GUYS!
Old 04-28-2013, 06:09 AM
  #215
383Nickles's Avatar
HOME STRETCH GUYS!
How many people ended up signing up for this group buy?
Old 04-28-2013, 11:36 AM
  #216
Originally Posted by 00silverzzzz
"They were built by cutting them up from some other application..........and they fit like crap"?
From your PM before I paid for the headers.
"Some background on them, I bought them off a fellow lsx swapper that had them on his 01 s10. Hes the one that made the mounts using fbody engine mounts and fabricated frame mounts, he made the headers himself using a kit. I bought the headers and mounts off him when he went a different route after 5 years. I used them for 2 years. I had to modify the mounts to move the engine back a half inch to get the engine where I wanted but his original holes are still there. With this the headers just barely kissed the heatshields on the firewall footwell area but didnt effect anything and i never had a problem with them. Ill find some pics of them installed and add them to my for sale thread."
"he made the headers ...using a kit .........moved the engine back a half inch .............didn't effect anything and I never had a problem with them"
Which version is correct?
Thanks
When I wrote the first part I thought they were built by cutting up a previously made longtube but since then I talked to the guy I bought them from (lowsub on s10forum) and he said that they were build with one of those do it yourself kits. as far as fitting they would fit perfect in the orginal mount holes but since Im running truck acc I wanted to move the engine back as close to the firewall as possible so I moved it back 3/4" which still left me with 3/8" at the closest point at the firewall which was the ground bolt on the back of the cylinder head. But with the engine back it required me to take a hammer to the heatshields and some of the cab in the footwell area. Clearance around frame drivetrain and steering shaft was fine though, no rattles or anything abnormal for the 2 years that I ran them.
Old 04-29-2013, 07:05 AM
  #217
I think there are about 25 sets in this first batch.
Jared at Current Performance is buying a few to stock (since they are designed for his mounts).
-Jason
Old 04-29-2013, 09:36 AM
  #218
Im impressed with my set.
Old 04-29-2013, 12:46 PM
  #219
I bet they fit your truck really well!
You gonna have it back up and running in the next few days?
Old 04-29-2013, 01:29 PM
  #220
I wish. I have to pull the engine and trans to modify my crossmember notch since Im not happy with the new one I made for the new mounts. Its only about a 1/8" clearance from the bottom of my oilpan. Swapping out the a/c heater box for a heat only box while waiting on the CircleD tq converter to arrive on thursday then I can toss that in and reinstall the engine and trans, Run lines for the trans cooler remove the seats and carpet to install the gear shifter and shifter cable to the trans, remove the clutch pedal, throw down lizard skin insulation on the cab floor and reinstall the interior. Then its just reinstalling the engine harness and other various components redoing the front half of my exhaust to meet up with the new headers then hopefully itll be back up and running. By the middle of May is my goal to have it running
Quick Reply: Stainless Works "special request" S10 Header group buy!
