Stainless Works "special request" S10 Header group buy! - Page 13 - LS1TECH
Closed Thread
Thread Tools Search this Thread
Old 07-26-2013, 11:51 PM   #241
Ok another ? When these were built what oil pan was on the truck Someone please chime in and let me know before I drop $900 and need another pan also to top it off
Z284thgen is offline
Old 08-24-2013, 03:56 PM   #242
Hrmm.. interested in these. Do they fit on 2nd gen s10 blazers? I have an xtreme I'd like to put a set on.
Thanks
distortion_69 is offline
Old 08-26-2013, 12:06 AM   #243
BigEd_72455's Avatar
I haven't bought these, but I swapped to the GMPP conversion pan before installation for added clearance. As for a blazer?? have no clue
BigEd_72455 is offline
Old 08-26-2013, 02:05 PM   #244
I had to grind my bellhousing down a ton to get them to clear. You can see those two cracks where the bellhousing is about aluminum foil thin.
Got them on!
Smacked the firewall pinch weld for half an hour, and took the grinder to the bolt and washer on the passenger UCA with my engine mounts all the way forward, and got them in! Putting the headers in, and then lowering the engine is a two-man job. Especially so you don't crush them. But overall, the passenger side goes in without much of a fit. Going to try drivers side later this week.
tefoster is offline
Old 09-11-2013, 08:08 PM   #245
Could we get a discounted price group buy going for these?
Lazered98 is offline
Old 09-18-2013, 07:21 PM   #246
Quote:
shop around some vendors will include these in GP's
Old 09-18-2013, 07:23 PM   #247
Well my set is going in a race truck so not much is left in the engine compt and the firewall has already been hammered in places. Guess it's just time to get it installed and find issues for my self
Old 01-11-2014, 07:38 PM   #248
Tweek's Avatar
Has anyone tried these on a 2nd gen blazer yet?
Tweek is offline
Old 01-12-2014, 11:41 AM   #249
^-- Has anyone?
If not, I'd gladly try them for a slight discount and the ability to return if they don't fit
Old 05-06-2014, 10:05 PM   #250
Tweek's Avatar
Quote:
Update!!! Installed a set on the 01 blazer I'm building a couple months ago and the fitment is awesome. No contact anywhere with the body, on had to shim the steering box with one washer and I'm running a stick steering shaft.
Tweek is offline
Old 05-09-2014, 09:38 AM   #251
What about for a 2002 4wd? All I've found so far is shorties which is probably the only option due to the front diff, but I have more clearance from my 6" lift.
willdevilman is offline
Old 12-10-2014, 07:10 PM   #252
Default 03 s10 ext cab question
i have stock upper and lower control arms at the moment, i dont know if this was ask but, will these fit it or do i need to modify anything. firewall, floor ??
thanks
03blacklsxs10 is offline
Old 02-06-2015, 09:04 PM   #253
Quote:
thanks
tubular uppers help out a ton most of us run speedway motors brand with long ball joint
Old 02-25-2016, 01:29 PM   #254
these are nice headers, I used a set on a 1st gen truck, I made my own solid mounts and set the motor as far back and low as possible, used the CTSV LSA oilpan and tubed the front crossmember. using ridetech a-arms
if tube #6 and 8 were reworked a bit it would allow for ALOT more a-arm clearance but im not sure how that would affect you guys with A/C
camarokid6771 is offline
Closed Thread
Related Topics
Thread Thread Starter Forum Replies Last Post
Huron Speed V3 GROUP PURCHASE Sale! BIGGEST SALE OF THE YEAR!!! Superman09 Forced Induction 351 02-16-2017 08:54 AM
Huron Speed LS1 Truck Manifold Turbo Kit *Group Purchase* Superman09 Forced Induction 299 01-31-2013 05:28 PM
Macewen Gauge Overlays and T/A Bezel. Group Purchase! SPECIALIZED STAINLESS Sponsor Group Purchases 51 11-25-2008 03:22 PM
May 18 Ohio Spring Track Rental GTO1_OHIO Midwestern Members 34 05-18-2008 05:38 AM
Tags
buy, camaro, camero, cpw, fit, generation, group, header, headers, long, ls1, s10, sonoma, stainless, tube, work, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
