Bolt in Fab 9 Housing
LS1TECH Sponsor
Originally Posted by kc10a
Do you make one that is a true bolt-in with the 4 channel ABS using stock brakes. Also, do you sell them completely set up with gears and all. I'd definitely be interested in one if you do.
LS1TECH Sponsor
Originally Posted by csjta2
Is this the same housing that Jay Billingsley uses?
How much can you narrow it? My car is minitubbed, just wondering how narrow you can go and still use the stock mounting points.
We can go 3inches per side on the narrowing.
LS1TECH Sponsor
Originally Posted by bjamick
What else would i need if i bought the 9" housing? Axles and what to work on my 99 TA.
LS1TECH Sponsor
Originally Posted by BAD *** TA WS6
Their main concerns were my gas tank. I should have been more specific. I'm actually lowered 2+ inches. But not much more than that. I've raised the car up a bit since I last checked.
I run coil overs all the way around, that's why I want to ditch the spring perches. I'd also be interested in having you guys mount up my swaybar before shipping it out.
I'll be running a big dog set of Mov-It brakes in the rear. I don't forsee any problems with how the brake caliper mounting brackets are positioned correct?
Pm me a ballpark price for the narrowed fabbed 9" with installed swaybar and say an Eaton posi 3.08 gear set. Doesn't have to be exact, just a rough estimate. I'll get back to you guys when I'm ready to order the new rear wheels, brakes and your rear.
Rob Borowski
Rob Borowski
