Bolt in Fab 9 Housing
Old 11-21-2006, 10:20 PM
LS1TECH Sponsor
Dave@BurkhartChassis's Avatar
Default Bolt in Fab 9 Housing....GP..
Hi everyone Burkhart Chassis is new to LS1Tech but the products are not. We are going to offer the Famous Fab 9 Housing at a price I don't think has ever been done. $999.00
You can see these and other products we offer at our new website below.
Old 11-26-2006, 08:11 PM
subtlez28's Avatar
Does your housing have provisions for a 3 channel ABS system?
Old 11-26-2006, 08:45 PM
skipperbisket's Avatar
hmmm, offering any kind of deal on trading my brand new moser 9" housing and 35spl. axles for my cash and one of the fab9 housings and new axles?
Old 11-27-2006, 04:57 PM
LS1TECH Sponsor
Yes it does. You can still run the stock brakes on our housings..
Old 11-27-2006, 04:58 PM
LS1TECH Sponsor
Sorry man the boss won' let me do that. You can still use your axles that you have..If that helps..
Old 11-27-2006, 06:56 PM
ls1king000's Avatar
Does the Fab 9 work with a stock/aftermarket (spohn) sway bar?
Old 11-27-2006, 08:39 PM
i need to go to a narrowed housing, thats why i wanna ditch mine. thanks, i'm going to try to sell mine to get one that you guys are offering.
Old 11-28-2006, 05:33 PM
LS1TECH Sponsor
Assuming it is the Spohn pro series you are talking about yes it will. The only thing that might be different is the tube size. Which our tubes are 3inch so you might need a different installation kit front spohn depending on what you have now..
LS1TECH Sponsor
Sounds good..Give me a call when your ready..
Old 12-02-2006, 12:53 PM
BMW ///M Nerd
BAD ASS TA WS6's Avatar
How hard would it be to fit a 2" narrowed Fabbed 9" in my car, thats lowered somewhere around two inches?
True bolt in housing? Can the spring perches be left off? How hard would it be to run my current LG swaybar?
Thanks in advance
Rob
Old 12-07-2006, 12:23 PM
LS1TECH Sponsor
Thanks in advance
Rob
Sorry fot thr the delay I still dont have internet service do to the storm.It should not be any problems fitting it in your car.. We can leave off the sripng perches if you like. The only thing you might have a problem with is your wheels..Thanks
Old 12-10-2006, 04:20 AM
BMW ///M Nerd
Originally Posted by Dave@BurkhartChassis
Sorry fot thr the delay I still dont have internet service do to the storm.It should not be any problems fitting it in your car.. We can leave off the sripng perches if you like. The only this you might have a problem with is your wheels..Thanks
A competitor told me differently. It took 3 weeks to get an answer out of them... I am low, and the gas tank is close....
How much does your fabbed assembly weigh? (including gear set/axles etc.) I'd just be looking to do an Eaton posi setup most likely.
As for the rear wheels, I'll be having 2 new sets made. With a much larger dish...
Old 12-10-2006, 11:33 AM
LS1TECH Sponsor
I must be missing something if they told you it wont work. Care to elaborate to why it wont work? The housings loaded with strage parts are around 180lbs. We are assembling one with all moser stuff so I will have the weight on that soon..
Old 12-10-2006, 12:01 PM
one more question, is the $999 for Any width rear, or stock width? if i were to buy one narrowed could i send my wolfe swaybar setup to you and have that installed too before you ship the housing?
Old 12-10-2006, 12:39 PM
ricknbird350's Avatar
do you sell complete rear ends? i sold my 12 bolt and want a 9" posi with 3.90,no abs
Old 12-10-2006, 03:09 PM
kc10a's Avatar
Do you make one that is a true bolt-in with the 4 channel ABS using stock brakes. Also, do you sell them completely set up with gears and all. I'd definitely be interested in one if you do.
Old 12-10-2006, 03:18 PM
JMBLOWNWS6's Avatar
Thats a 4 channel setup. Not a 3 channel.
Old 12-10-2006, 03:47 PM
LS1TECH Sponsor
Yes any width and yes we can install your sway bar.
Old 12-10-2006, 03:49 PM
LS1TECH Sponsor
Yes we do. We offer Moser Axles,Centersections and Aerospace brakes. Other brands are available this is just what we use the most..
Old 12-11-2006, 05:08 PM
BMW ///M Nerd
Their main concerns were my gas tank. I should have been more specific. I'm actually lowered 2+ inches. But not much more than that. I've raised the car up a bit since I last checked.
I run coil overs all the way around, that's why I want to ditch the spring perches. I'd also be interested in having you guys mount up my swaybar before shipping it out.
I'll be running a big dog set of Mov-It brakes in the rear. I don't forsee any problems with how the brake caliper mounting brackets are positioned correct?
Pm me a ballpark price for the narrowed fabbed 9" with installed swaybar and say an Eaton posi 3.08 gear set. Doesn't have to be exact, just a rough estimate. I'll get back to you guys when I'm ready to order the new rear wheels, brakes and your rear.
Rob Borowski
Quick Reply: Bolt in Fab 9 Housing
