High Flow LSx Injectors All Flow Matched
LS1TECH Sponsor
We now are offering high flow injectors for Just about any LS based vehicle in need of a bigger fuel supply for all that additional horse power you have added or are going to add.
We now have available GM factory injectors for LS1, LS6, LS2 and LS3's that are flow matched and upgraded to support 750 + horse power applications.
LS2 60lbs:
$325.00 shipped - lower 48.
Perfect for any LS2 car in need of more fuel with no adapter's needed, will also work with LS1 and LS3 but will require either spacers or injector connector adapters. Should be able to support up to 750 + hp. The 60lbs is based on 3 bar, or 43.5 psi. where as LS cars run 4 bar at 58psi, these are realistically about 70 lb injectors. Often times we can provide the adapter kit based on your specific application.
LS3 60lbs:
The 60lbs is based on 3 bar, or 43.5 psi. where as LS cars run 4 bar at 58psi, these are realistically about 70 lb injectors. Often times we can provide the adapter kit based on your specific application. Perfect for any LS3 car in need of more fuel with no adapter's needed, will also work with LS1 and LS2 but will require either spacers or injector
LS1 42lbs:
Upgrade again based on 3 bar, these at 58psi are obviously greater than 42lbs as well.
White GM LS1/6:
Upgraded from 36lb to 48 - These are very much like the green top Ford SVT injectors but with a much better flow pattern that is much better to tune.
LS2 60lbs:
LS3 60lbs:
LS1 42lbs:
White GM LS1/6:
LS1TECH Sponsor
Not sure if these work in Cobras, sorry.
What is listed is what we are offering and have available, except that we just ran out of LS3 60lb'ers until after the Holidays.
The LS1 / LS6 48lb injectors (based on 43.5 psi / 3bar) are realistically apx. 55 lb injectors, that will support 600 rwhp for a FI car or 700 rwhp sprayed or NA.
Thanks
Dan
Fasterproms
