High Flow LSx Injectors All Flow Matched
LS1TECH Sponsor
We now are offering high flow injectors for Just about any LS based vehicle in need of a bigger fuel supply for all that additional horse power you have added or are going to add.
We now have available GM factory re sized injectors for LS1/LS6, LS2 and LS3's that are flow matched and upgraded to support 750 + horse power applications.
LS2 72lbs:
$325.00 shipped - lower 48.
Perfect for any LS2 car in need of more fuel with no adapter's needed, will also work with LS1 and LS3 but will require either spacers or injector connector adapters. Able to support up to 750 + hp. The 60lbs is based on 3 bar, or 43.5 psi, where as LS cars run 4 bar at 58psi, which on LS fuel pressure of 58 is 72.25lbs. If needed we may be able provide the adapter kit based on your specific application.
LS3 72lbs:
Perfect for any LS3 car in need of more fuel with no adapter's needed, will also work with LS1 and LS2 but will require either spacers or injector connector adapters. Able to support up to 750 + hp. The 60lbs is based on 3 bar, or 43.5 psi, where as LS cars run 4 bar at 58psi, which on LS fuel pressure of 58, is 72.25lbs.
LS1/6 57lbs:
$300.00 shipped - lower 48
This set re sized and flow matched LS1/LS6 injectors at 58psi are rated at 57.8 lbs.
These are the standard injector that come with Procharger kits and are the stock injectors that come in the Pontiac GTP SC 3.8L. They are my personal favorite injector as they tune perfectly w/ zero drive ability issues and have a great spray pattern. I feel they are much more superior to the popular Lightning SVO / green top 42lbers. These re sized and flow matched injectors will support 700RWHP w/ a stock fuel pump (C5) and more with a greater volume pump.
Jeremy Formato
No spacers or adapters needed with LS1/LS6 vehicles.
We can provide an injector flow rate slope for these injectors.
LS2 72lbs:
LS3 72lbs:
LS1/6 57lbs:
Jeremy Formato
