Introducing The Nitrous Outlet Plastic Series Dedicated Fuel Systems.
Old 02-01-2010, 11:16 PM
Nitro Dave's Nitrous Outlet's Avatar
Default Introducing The Nitrous Outlet Plastic Series Dedicated Fuel Systems.
Many of you have been asking for it and we have been way to busy to just post and share. Well here it is and it’s CHEAP for NOW….. So jump on this deal and get ready for race season.
Newly released from the company that had the ingenuity to create and introduce the all in one dedicated fuel systems to the performance industry Nitrous Outlet is proud to release our plastic series dedicated fuel systems.
Made from molded plastic these dedicated systems consist of an in tank fuel pump that feeds a Aero motive return style regulator that hard mounts to the tank. The system comes complete with all hoses, fittings, relay, relay harness and wiring diagram. They are also foam filled..
Simply drop in. Hook up the hose, wire, and set fuel pressure.
This is our first released design in this series. This unit is a copy of our Aluminum F-body fuse area dedicated fuel system that mounts on the radiator core support on the driver’s side beside the radiator.
This unit requires no alteration to the vehicle to mount. Simply bolt in place.
We have found that this tank works in many other applications than it was attended for so even if you do not have an F-body you may entertain the use of this system.
These plastic tanks were a first production run and I am not 100 percent happy with the stamping of our logo. Most will never even notice the imperfection but we know its there and the mold company cut us a deal and we are going to pass the savings on to you.
This is a while supplies last type of sale. We only have 50 of these systems and they will go quickly at this killer price, so don’t miss out!
This complete system as an introductory price is only 549.99 while supplies last!
You can call in your order at 1-866-648-7637
I will have it added to the website shortly..
Old 02-02-2010, 12:25 PM
02sleeperz28's Avatar
Wow! Very nice.
Old 02-02-2010, 01:07 PM
Is this a high or low pressure system?
Old 02-02-2010, 01:20 PM
They are designed to be used with either Low or high pressure. We achieve this by using a walboro fuel pump feeding the aeromotive regulator. By simply changing out the sring in the regulator we can choose the fuel pressure range.
The system comes with both springs..
Dave
Old 02-02-2010, 03:55 PM
litle88's Avatar
Sounds like a good design, will you guys be having a sale soon on your plate systems for us folks who are gonna be getting some uncle Sam money? so we can jump on this.
Thanks
Old 02-02-2010, 04:08 PM
97blkz's Avatar
Very nice, maybe in the future!
Old 02-03-2010, 09:20 PM
For those asking where these mount. They mount in the same location as our aluminum series...
Here is a picture for reference.
Old 02-03-2010, 10:36 PM
CaMaRo67RS355's Avatar
can you pm me and let me see the differences in the plastic and aluminum setup? are their any other differences between the plastic and aluminum ones other than the plastics are cost effective?
Old 02-03-2010, 11:22 PM
You nailed it. All the parts are exactly the same other than the tank itself. We have to buy large numbers of this tank to get them this cost affective however it also helps because there is less time in the build construction.. Only difference is plastic VS alumnumim.
Old 02-11-2010, 12:03 AM
how much does the same system run but with an aluminum tank?
Old 02-15-2010, 10:59 PM
They are here.. 714.00
http://www.nitrousoutlet.com/catalog...86&product=945
Old 02-16-2010, 08:01 AM
mcamarols1's Avatar
Im gonna get in on this one!!! Any word on you F-body wiring harness?? any chance of getting a good deal on both?
Old 02-25-2010, 05:20 PM
Hopefully we will be able to start shiping the wiring harness by the end of next month..
Old 03-13-2010, 08:10 AM
mcamarols1's Avatar
I got mine in yesterday!!! Thanks Nitrous Outlet!!
Old 03-17-2010, 10:18 PM
LS88FoxBody's Avatar
I need a setup that will go on passenger side in 91 Foxbody. similar to the wiper resvoir one. Any Ideas?
Old 04-14-2010, 11:40 AM
We can build anything.. Give one of our techs a call. We may already offer what you are after.
Dave
Thought I would let everyone know all the orders are filled and we have some left. They are built and sitting on the shelf ready to ship.
Dave
Old 04-22-2010, 06:41 PM
BBFROMAL's Avatar
im interested in one. but im also looking into a 102mm plate possible dual shot. ima be ordering a new 102mm fast. was wonderin what youd have to help me out. i saw the 102mm single shot kit on ur web site and thatd be ok but id need a 6an main line n etc.
Quick Reply: Introducing The Nitrous Outlet Plastic Series Dedicated Fuel Systems.
