Lme 365” ls2 sb for boost ready to go!!
LS1TECH Sponsor
LME has one 365” LS2 shortblock built for boost ready to go!
Shortblock is fully balanced, blueprinted & assembled.
Parts used:
*GM LS2 aluminum block (new)
*GM nodular iron 3.622” stroke crankshaft with 3/16” key way
*Callies 6.125” H beam rods w/ARP 2000 7/16” bolts
*Wiseco forged 4.005” x -11cc FI pistons w/tool steel pins & skirt coating
*NPR rings for high heat applications-stainless top, napier 2nd, 3mm oil
*Clevite main & rod bearings
*Dura Bond one piece cam bearings
*ARP main studs
*All oil galley plugs & dowel pins
Compression ratios:
9.1:1 w/72cc chamber
9.5:1 w/68cc
9.9:1 w/65cc
10.5:1 w/59cc
Price is $3500.00
Feel free to ask any questions about the set up and how it will work with your combination.
Thank you,
Bryan Neelen
LME
713-849-4505
sales@latemodelengines.com
Parts used:
*ARP main studs
Compression ratios:
9.5:1 w/68cc
9.9:1 w/65cc
10.5:1 w/59cc
Price is $3500.00
Thank you,
Bryan Neelen
LME
713-849-4505
