HPE Cam and Install Special
Horsepower Engineering will be offering a cam special from now until the end of October. The cam kit will include a Comp cam, Comp springs, pushrods, install and the tune.
Camaro, GTO will be $1450.00.
C5/C6 Corvette's, 2010 Camaro/G8 gxp LS3 will be $1650.00. (C6Z06 $100 more)
Optional items to be added
LS3 Oil Pump $150.00
Double Roller Timing Chain $109.99
Install t/c & oil pump $50.00
Install heads at the same time add $600.00, this will include head gaskets, stock head bolts and the oil & filter.
LS6 Heads Stage II $1250.00
Trickflow Heads $2250.00 (rocker shim kit to use factory rockers $180/with rocker bearing upgrade $295)
AFR Heads: Call For Pricing
G8/2010 Camaro L99 DOD delete cam kit $2650 installed and tuned
HPE stage 1 square port cam
HPE .650 lift dual valve springs
GM LS7 Lifters
GM Balancer Bolt
GM LS2 Valley Cover
GM LS7 Camshaft Sprocket
GM Valve Cover Breather Block-Off
GM Header Gasket
GM Ls2 Timing Chain Dampner
GM PCV hose for non-DOD applications
GM LS2 Lifter guide kit
GM Camshaft Retainer plate bolts
GM Timing Chain Bolts
ARP Head Bolts
GM MLS Head Gaskets
Chrome Moly pushrods
Oil Change Mobile 1 oil
LS3/L92 stage 2 heads Hand Ported $1650.00 (G8's free install with purchase of g8 dod delete cam kit installed)
All heads have springs installed. $250 will be subtracted from cam kit on dod delete application and $100 on non dod.
Please call to schedule your install.
GM LS7 Lifters
GM Balancer Bolt
GM LS2 Valley Cover
GM Header Gasket
ARP Head Bolts
GM MLS Head Gaskets
