Huron Speed Torque Converters
Old 02-04-2012, 01:45 PM
LS1Tech Sponsor
Superman09's Avatar
Default Huron Speed Torque Converters
Huron Speed is now pleased to offer Torque Converters. No matter the application, we can have you covered! These are made specifically for Huron Speed per YOUR order and needs. These are not off the shelf converters, but rather built to your specs for your application!
We can cover all applications, whether you have a 93-97 F-body, 98-02, TH400 converted, 2010+ Camaro A6, C5 Corvette, C6 Corvette A4 & A6... you name it, we can get it done!
We have categorized the converters into 2 main models, the C1 and the C2:
Huron Speed C1 Torque Converter
This converter is good for those cars that are stock, bolt-ons, cam only, NA applications, or even small nitrous use.
This converter is good up to 750 hp
Good for smaller nitrous use up to 4000 stall speed.
If you would like WOT lock-up, we highly recommend the C1.3 with the triple lock up discs
-Billet Cover, Billet Lock-up Piston
-9.5" Converter
-Standard is a single disc, triple disk is also available (WOT lock-up) (C1.3)
-All converters will have a BILLET cover, BILLET lock-up pistons, furnace brazed and tig welded fins, and balloon plates
Huron Speed C2 Torque Converter
This converter is good for those cars that are Boosted (Supercharged or Turbo) as well as higher Nitrous use.
This converter is good up to 1250 hp
If you would like WOT lock-up, we highly recommend the C2.3 with the triple lock up discs
-10.5" Converter
-Standard is a single disc, triple disk is also available (WOT lock-up) (C2.3)
All converters will have furnace brazed and tig welded fins, billet covers, balloon plates, and billet lockup pistons.
We can offer your desired Stall Speed rating from 3000 on up!
We can offer 9.5"-10.5" sizes as well depending on your power needs, as well as either single or triple disc lock-ups!
These converters will come with Huron Speed engraved on them along with a serial number so we can always identify the unit should you ever want to sell down the road!
Please view on the website for options and such, and as always if you have ANY questions, feel free to ask!
http://shop.huronspeedproducts.com/T...erters_c17.htm
Also be sure to check us out on Facebook and "Like" us to keep in touch with all our current specials as well as our constant new product updates!
Click here to check us out!
www.facebook.com/HuronSpeed
Interested in knowing what is inside your torque converters? No secrets here, VERY high quality components inside!
Billet Cover, Huron Speed engraved!
Billet lock-up piston back side!
Front of lock-up piston, 1.5" wide, .070 thick material!
Hardened 4140 Chromoly Pump Hub and Turbine Hub!
Dual fin braced turbine!
Comparison to a typical single fin braced turbine from the competitors!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 02-07-2012, 12:46 PM
LS1Tech Sponsor
Superman09's Avatar
We have now categorized the Torque Converters into C1 and C2 models!
__________________
Old 02-13-2012, 09:34 PM
LS1Tech Sponsor
Superman09's Avatar
Check out the added pictures to see what goes inside of these torque converters!
__________________
Old 09-14-2012, 11:23 PM
trbokmro's Avatar
am i missing something? i looked all over the site linked to the address above and didn't see 1 item for c5 converters........
Old 09-15-2012, 12:59 AM
LS1Tech Sponsor
Superman09's Avatar
Sorry, unfortunately this line of converters is no longer available.
__________________
Quick Reply: Huron Speed Torque Converters
