Cam and Cylinder Head Install Gasket Kits- GM Parts!
Old 02-20-2013, 03:45 PM
Ryan@BallisticSpeedParts's Avatar
Default Cam and Cylinder Head Install Gasket Kits- GM Parts!
CAM INSTALL KIT
Our Cam Install Kit includes all the necessary gaskets to complete a cam swap in your LS Engine. All parts are Genuine GM!
Our kit includes the following:
• Front Timing Cover Gasket
• Front Crank Seal
• 2 Water Pump Gaskets
• GM Balancer Bolt
You may also choose to add the following options:
• Heavy Duty LS2 Timing Chain Upgrade
• New Oil Pump O-Ring
Our Cam Install Kit starts at $49.95
=====> CLICK HERE TO VIEW <=====
Old 02-20-2013, 03:49 PM
CYLINDER HEAD INSTALL KIT
We offer two different kits to make your cylinder head swap a smooth and hassle free process!
Our Basic Head Install Kit includes all of the necessary gaskets and bolts to perform a quick head swap on your LS Engine. All parts are Genuine GM with options for Cometic head gaskets!
Basic Kit Includes:
• Your Choice of Headgaskets
• Pair of GM head bolt kits
Our Basic Head Install Kit starts at: $99.99
Our Deluxe Head Install Kit includes all of the gaskets and bolts found in the Basic Kit and then some! All parts are Genuine GM with options for Cometic head gaskets!
Deluxe Kit Includes:
• 2 Valve Cover Gaskets
• 2 Exhaust Manifold Gaskets
• 4 Coolant Port Seals
Our Deluxe Head Install Kit starts at: $169.99
Quick Reply: Cam and Cylinder Head Install Gasket Kits- GM Parts!
