Cam and Gasket Kits! One stop shop
Cam Kits - $679
-Comp custom grind cam
-BTR Dual .660 Valve Springs (w/steel retainers)
-BTR Pushrods
BTR Valve Spring Kits
-w/Steel retainers - 219
-w/Titanium retainers - 299
Comp Custom Grind Cams $385
COMPLETE Cam Swap Kits - 754
-BTR Pushrods
-GM LSX Timing Cover Gasket
-GM LSX Water Pump Gaskets
-GM LSX Front Crank Seal
-GM LS1 Crank Bolt
Cam Swap Gasket Kit - $75
-GM LS1 Crank Bolt
Heads/Cam Gasket Swap Kit: $200
-GM LS1 Head Gaskets
-GM LSX Header Gaskets
-GM LS1 Crank Bolt
-GM Head Bolts
Optional upgrades include:
LS2 Timing Chain - add $42
HRI Ported LS6 Oil Pump - add $135
ARP Head Bolts - add $100
GM LS7 Lifters - add $130
COMP Trunnion Upgrade Kit - add $130
Check out the online store at www.hubbardracinginc.com!
-BTR Pushrods
-BTR Pushrods
-GM LS1 Crank Bolt
-GM LS1 Crank Bolt
-GM LS1 Crank Bolt
-GM Head Bolts
