Front end kit special
Old 02-27-2014, 10:27 AM
LS1Tech Premium Sponsor
MidwestChassis's Avatar
Default Front end kit special
The package includes a K member, Upper and Lower A arms, And a manual pinto rack and pinion steering kit.
It comes with all the hardware, balljoints and brackets to completely replace your stock front end. It all comes in a powdered coated finish.
The total price is $1500 and comes with free shipping!!!
Ships the same day as ordered!!
Old 04-06-2014, 04:25 PM
4bangermustang's Avatar
good deal
Old 04-07-2014, 10:05 PM
VTC_WS6's Avatar
Does this utilize the stock spindle? Can it be upgraded to a 'full race kit' to incorporate the spindle and brake kit?
Old 04-08-2014, 08:40 AM
ssvert99's Avatar
This particular package is for factory spindles. The MWC race front end package uses our exclusive lightweight spindle that does not use ball joints, so the control arms are different between the two. I have adapters in the works that will allow the conversion, but will be a while before they are available. At the end of the day it is possible, just not right now, so it will depend on your time line that you are looking for the change.
Old 04-08-2014, 02:20 PM
Rare96LT1Formula's Avatar
How much without the manual rack?
Need to order some new shocks from you guys too!
Old 04-19-2014, 11:20 AM
ssvert99's Avatar
I can do that package at 1025.00 shipped. If you order the shocks at the same time the deal gets even sweeter!
Old 04-19-2014, 11:24 AM
Zmg00camaross's Avatar
Defiantly a good deal!!
Old 04-25-2014, 02:27 AM
02ss1984's Avatar
Definitely interested in this :-)
Old 05-22-2014, 02:00 PM
Kits in stock ready to ship call us today with your needs.
Old 06-02-2014, 08:10 AM
ssvert99's Avatar
Give us a call. We can help you with this or any particular suspension combo you need!
Old 06-13-2014, 09:41 AM
We offer 5 levels of suspension kits from just a K-member to our all out race kit. Call us with your suspension needs.
Old 06-27-2014, 08:23 AM
ssvert99's Avatar
Stage 1= Mild steel k-member and full adjustable lowers 750.00
Stage 2= K-member, full adjustable uppers and lowers 1025.00
Stage 3= K-member, full adjustable uppers and lowers, Viking d/a shock package 1575.00
Stage 4= k-member, full adjustable uppers and lowers, manual steering rack-bumpsteer kit-stering shaft, Viking d/a shock package 2060.00
Stage 5= MWC full race front end pkg. Chromoly k-member, 2pc cm lowers, cm adj uppers, cm spindles, Strange Pro brakes, Viking d/a shock pkg. 3400.00 This is the same package that the record setting 6 second Ohio Boys use, as well as others like Brian Black, Ray Litz, Andy Essary, and Eddie Krawiec just to name a few.
Menscer, Afco, and Strange shocks are available with any of the packages.
We also offer a race style 2pc adjustable lower arm for the oem spindles on stages 1-4. This option adds 50.00 to the price and requires the use of a 6" wide or less wheel. This option includes the k-member with single hole style brackets that eliminate the slotted style hole for the lower arms that commonly have issues keeping the alignment setting in place w/ aftermarket k-members.
These are shipped prices, and we can accommodate other customization if need be for those needing different options. As always MWC GUARANTEES the lowest prices and highest quality. If you find a better deal on similar components we will beat it!
Quick Reply: Front end kit special
