Switch Your Exhaust From Loud To Quiet By Pushing A Button w/ XForce @ Hinson
Old 02-09-2016, 10:18 AM
HINSON Motorsports's Avatar
Default Switch Your Exhaust From Loud To Quiet By Pushing A Button w/ XForce @ Hinson
Now in stock direct from Australia is the X-Force 2010+ Camaro Varex cat-back exhaust system. This is a full 3" stainless steel exhaust system that switches, by remote control, from loud to quiet.
We Have 2 Of These Kits & Once They Are Gone It Will Be Months Before They Are Back In Stock
Call To Order TODAY 205-909-9402
Price $1099.99 FREE Shipping to lower 48 states
VAREX mufflers utilize a patented technology to combine both the design of the stock muffler and the performance muffler into one single compact unit. A sophisticated butterfly valve mechanism is implemented to redirect the exhaust gas flow and vary be-tween the two. For higher sound level, the exhaust flows are directed through the opening path and produces maximum power with a robust sound level (or the “sports car note”) and near-zero resistance.
When the muffler is switched to the quiet mode, the exhaust flows are directed through the chambered path (similar design with the stock muffler), and produces minimum sound level that gives you the best in-car comfort. Angle of the valve is also controllable, which can be adjusted to stop at various points between sports mode and silence mode. This gives you further freedom to set the optimal sound level according to your desired preference.
Sample Video
Old 02-18-2016, 10:35 AM
In stock.
Quick Reply: Switch Your Exhaust From Loud To Quiet By Pushing A Button w/ XForce @ Hinson
