Mail Order Tune Swaps $100 for July
Old 07-05-2016, 11:16 AM
LSX Power Tuning's Avatar
Default Mail Order Tune Swaps $100 for July
After tons of request we are finally running a sale for those doing stock engine swaps. The sale only applies to those mailing in their PCM and doing a stock motor swaps. It includes deleting VATs, programming tire size, gear ratio and deleting all other necessary DTC's in the PCM for the swap to run correctly. If you have a different camshaft, different heads, boost or nitrous this sale does not apply.
$100 total including return shipping!
Enter 00AN8K5Q1UTZ at checkout
Old 07-06-2016, 11:21 AM
Spectre86's Avatar
segment swap for a 4l80, set for ID1000's, remove VATS.
engine setup is a forged motor, 91mm turbo, jakes 4l80, etc. I just need it to be able to idle with those injectors and the 4l80 work properly so the tuner can atleast have it idle and shift as a base.
Old 07-06-2016, 12:28 PM
We can do it a base tune for that, unfortunately it won't fall under the current July sale.
Old 07-06-2016, 03:43 PM
JC316's Avatar
What do you consider to be a stock swap? I have an 00 WS6 with an LQ4 swap. Still using the stock LS1 camshaft and it has the stock 317 heads that came on the motor.
Old 07-06-2016, 04:35 PM
The sale is for guys doing ls swaps in other vehicles to get them up and running. When doing a swap in a non ls vehicle it wont even run without getting the pcm reprogrammed. This sale is just a cheap way for those guys putting stock motors in something to get them up and running and not throwing tons of codes. If they do not use a stock motor for the swap then the sale pricing doesnt apply. If you wanted the items in bold listed above done I could do it under the sale however I dont recommend it unless you just wanted to get rid of a check engine light. You would really benefit from our actual full mail order tune with your mods.
Old 07-15-2016, 08:30 AM
jzingre's Avatar
PM Sent. Just wanted to make sure you received my ecu.
Old 07-15-2016, 10:19 AM
We received it yesterday. You will receive an email with tracking number when it ships back out. Tracking numbers may not be valid until after 7pm sometimes. You can also log onto your online store account and check the status of your ecm also.
Old 07-25-2016, 06:20 PM
Sale still going on for the rest of the week.
Quick Reply: Mail Order Tune Swaps $100 for July
