Single-Piece Replacement LS Oil Pan Gaskets for $24
LS1Tech Sponsor
Complete Oil Pan Swap Kit for LS1 Camaro / Firebird (F-Body)
The F-Body oil pan is the pan of choice for most engine swaps as it provides the most steering rack clearance of any GM pan as well as generous ground clearance. Using a factory GM pan allows you to retain the structural rigidity of a cast aluminum pan.
Includes:
-GM Part # 12628771 - GM LS1 F-Body oil pan, gasket, stock baffle, drain plug and mounting hardware (Old GM Part # 12558899)
-GM Part # 12551581 - GM LS1 F-Body oil dip stick
-GM Part # 12551577 - GM LS1 F-Body oil dip stick tube
-GM Part # 12558251 - GM LS1 F-Body oil pickup tube
-GM Part # 12558253 - GM LS1 F-Body windage tray
Applications:
1998-2002 Pontiac Firebird Formula and Trans Am
1998-2002 Chevrolet Camaro Z28 and SS
Bolts to all GM Gen III & IV LS family engines including LS1, LS6, LS2, LS3, LS7, LS9, L76, L98, L92, L93, L99, LQ4, LQ9, LSA, LSX and V8 Vortec variations.
$370.95 (free shipping with in the 48 states)
If you have any questions, Feel free to call me at 407-705-3054 * 105 or email me at Kevin@ImprovedRacing.com
Includes:
Applications:
LS1Tech Sponsor
We now have replacement LS oil pan gaskets available for $24. Unlikely the factory gasket, which is made like a jigsaw puzzle of 4 pieces, these are made from a single piece of aluminum. The gasket seal is silicon like the factory gasket. Designed using original GM CAD models for a perfect fit.
At $24 bucks these are less costly than the factory gasket and won't give you any sealing issues.
Available here: http://www.improvedracing.com/gasket...nes-p-660.html
Single-piece replacement LS oil pan gasket.
