Mac Performance rear end girdles for 10 bolt $122.95 SHIPPED !!
Strengthen your GM rear end with the strongest rated support covers you can buy !! These 356 T-6 Aluminum covers help keep the rear end housing from distorting under load , preventing increased side bearing clearance and ring gear deflection . Two special adjustable grade-8 support bolts help prevent both bearing main caps from movement and possible breakage . Increased fluid capacity , fill , drain plugs and hardware .
Thanks ,
Mike
www.neweraperformanceparts.com
sales@neweraperformanceparts.com
585-865-1832
Thanks ,
Mike
585-865-1832
Thanks ,
Mike
585-865-1832
Thanks ,
Mike
585-865-1832
You go to www.neweraperformanceparts.com , and in the camaro/firebird section click on drivetrain , scroll down until you find the girdle , click order now and fill out the online order form . Or , you can just call 585-865-1832 between 10am and 5pm EST . We also take paypal so you can send payment to sales@neweraperformanceparts.com (from confirmed addresses only) .
Thanks ,
Mike
585-865-1832
Thanks ,
Mike
585-865-1832
