Short Block Assembly..??
I have all of the pieces and I need someone to put it together.
Here is what I have.
LS1 stock block (needs to be cleaned up)
Diamond 3.905 bore 20cc dished pistons with Pro select rings
Clevite cam, rod, and main bearings
ARP main studs and rod bolts
Stock crank
Rods The new Calllies rods
What I want is the Block bored and cleaned with the rotating assembly balanced and put together.
This will be a F/I setup and the target h.p. is 700@6800
I just need a PM for assmebly. I will take care of shipping.
Stock crank
