Diamond Racing Piston Special
Old 01-14-2003, 02:04 PM
Dave@Ramchargers's Avatar
Default Diamond Racing Piston Special
Okay guys
Stock replacment Diamond Piston #15511500 $559.99
3.905 Bore
Forced Induction Diamond Piston #15511503 $559.99
3.905 bore -8.6 Dish
We also have the Diamond Racing Rings for these pistons $195.99
Im thinking we will run this through the month. Phone orders only guys.
888-293-7267
Ask for me or Kevin.
Also if there is any thing you are looking for parts wise. Or if you would like to get a GP goin let us know.
Thanks
Old 01-14-2003, 02:11 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,090 Likes on 718 Posts
Default Re: Diamond Racing Piston Special
Dave, might be good to know if those are 3.898 bore or 3.094 bore pistons.
Old 01-14-2003, 02:39 PM
John,
LOL.. i always leave out the most important parts
Old 01-14-2003, 04:10 PM
theblur98ss's Avatar
What about the #11506? I'm gonna need a set of them and rings...for a 4.100 bore.
Old 01-16-2003, 08:46 AM
Ill have to check on them for you.. they will be a little more money..
Old 01-16-2003, 10:30 AM
11506 is $579.99 <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old 01-16-2003, 08:10 PM
1bad2k2ta's Avatar
How about the 11502s. I want to go with a 6.125 rod. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 01-16-2003, 10:34 PM
red53gmc's Avatar
Can someone give me the quick rundown on why the 6.125 over the 6.100?? Just wan to clarify things before I order my rods and pistons.
Thanks
Old 01-18-2003, 12:17 AM
How did i forget about the #11502's?!?! $559.99
Old 01-18-2003, 09:16 PM
frcefed98's Avatar
what red53gmc said. why the 6.125 and not the 6.100. I want to use the 11502 with 6.0heads should this net me a comp ratio of around 9.5-1?
Thanks,
J
Old 01-20-2003, 08:48 AM
unless i read the info wrong the only difference is rod lenth. the compression height on the two are different to keep the same compression...
I believe its about 9.5 or maybe a tad higher. I do not remember what the cc of a 6.0 head is off hand.
Quick Reply: Diamond Racing Piston Special
