Textralia (Aussie) clutches are back in
I just received another pallet load and sent them out for balancing. I custom balance every set. The flywheel and pressure plate are zero balanced separately. This way you can swap flywheels or pressure plates around without rebalancing.
They come with flywheel, pressure plate, disc, new slave and bearing, ARP bolt kit and installation tool.
I have them for $949, including the double balancing. They come with slave and ARP bolts. I'll do a little better if afew of you get together.
They're pretty smooth for an aggressive clutch. Best I've found so far. You might get a a little bump in stop and go traffic, but that's about it.
It's perfectly smooth if you're the least bit aggressive with it.
Originally Posted by hugger1975
noob question alert.
do i need a flywheel too?
Andy, what kind of price break are we lookin at for a GP, and how many people need to be in on it for it to get that price? Thanks!
I'll do them at $979 shipped, no minimum.
If you really want to do a GP, I can do them for $929, shipped. (10 minimum) BUT: For that price I won't be able to have them double balanced. They come balanced "as an assembly" That means that as long as you keep the same pressure plate and flywheel together, you're OK. As a conveneience to my customers, I have each piece balanced separately. That way, if you wanted to change to an aluminum flywheel or swap just the pressure plate, you'd be OK.
There's nothing wrong with a balanced assembly. I just can't afford to ship them out here, rebalance them and then ship them out. The GP units will come directly from Texas.
I've talked with them and I've been authorized to do this. Just let me know who's in.
Originally Posted by cyphur_traq
noob's should read more carefully. check his first post....it lists everything in the kit. it just so happens....it includes a flywheel
DOH.........
jk
I am in.........
Andy, jumping over from the Aussie Clutch GP thread. you can count me in towards the 10 GP deal. Not, too concerened with double balance as I would probably go this route again, the next time a clutch is needed, tehn get a new disc and have the original turned and balanced the following time. I do this with brake rotors.
You PM'd me earlier, but can any additional discount be offered if picked up locally in Oxanrd, or did you mean that they would be drop shipped from Texas to us?
Thanks, and sorry to be such a PITA with the questions,
David
David
i really really really really need a clutch right now but need to wait until next friday to spend the money, how long would the group price be available? i think my stock clutch is actually falling apart or somethin....
