HUGE Ram Clutches Specials!!
We have a ton of Ram Powergrip and Powergrip HD LS1/LS6 clutches on the shelf looking for new homes! So, we are running a special on these clutches, and we will include FREE SHIPPING via UPS Ground in the continental United States!
*Ram Powergrip - $369!
*Ram Powergrip HD - $389!
*Ram Billet Steel Flywheel - $239!
*Ram Adjustable Master Cylinder - $159!
This special is good through Wednesday, June 17th, so feel free to give us a call if you would like to get one coming your way. They are in stock and ready to ship!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
LS1Tech Premium Sponsor
Originally Posted by Country Boy
WHat does the HD come with and will it work with a resurfaced flywheel?
Let me know if you have any other questions or concerns.
Trevor
Originally Posted by Trevor @ Texas Speed & Perf.
The Powergrip HD is Ram's "stage 4 comparable" clutch that's rated to 600 HP, and it comes with the disc, pressure plate, and alignment tool. It will work just fine with a factory resurfaced flywheel, but I would recommend running one of their shims since it is resurfaced. It is .150" thick, and it will give you the added travel that some want. Some are under the impression that the adjustable master cylinder will solve this problem, but it only limits the amount of travel, it will not provide you with more. The shims are $12.50, FYI. The majority of guys install the clutches without the shim, but it will keep you from having to pull the transmission out again should you need the extra travel.
Trevor
Trevor
Does it come with a new throw out bearing?
Country Boy - The life of a clutch will greatly depend on how hard you run the car, both on the street and on the track. However, you'll FAR surpass 5,000 miles!
The clutches do not come with a new throwout bearing. However, if you upgrade slave cylinders GM does send them out with new throwout bearings. We stock the 2001+ upgraded GM slave cylinders for $125. It is HIGHLY recommended to upgrade to the revised slave if you are still running the factory 1998-2000 GM slave cylinder.
Trevor
Trevor
How does the HD run. Is it for the track only. Is it real gittery like the spec stage 4 and my last question is. Can I get a price with the Ram HD and Billet flywheel shipped to 33615 2 day. I will be ordering it tomorrow but would like it here by friday so I can install it on saturday.
Tim
Tim
Orders can be placed online. We will have the pricing changed this evening to reflect the sale prices.
blackcat - I believe Jon took care of you this morning. Let me know if you have any other questions or concerns.
The HD clutch is sprung, so it won't have as much of the vibration upon release.
Let me know if any of you have any other questions.
Trevor
Trevor
Trevor,
I have heads/cam waiting to go in my car. Hoping to hit ~500 fwhp with it. Might have a small nitrous shot a little later (75 shot). I don't go to the track much at all (4-5 times a year at most), mainly street driving.
Which ram clutch would you recommend? Also, is there any warranty with the clutches? Thanks, Pete.
