** TTP Turn-Key Motor Packages
Old 11-16-2005, 08:48 AM
TTPMatt's Avatar
Default ** TTP Turn-Key Motor Packages
All of our turn-key packages include the following:
- Remove & Reinstall Motor/Trans
- Remove & Reinstall Top End Motor (Heads, Intake, etc.)
- Remove & Reinstall Bottom End Motor (Oil Pan, Camshaft, etc.)
- Install any clutch or torque converter combination is included.
- LS1 Edit Full Custom Dyno Tuning
- All fluids (Oil, trans, brakes), gaskets and filters necessary.
- All motors include 1 year/15,000 mile naturally aspirated guaranteed labor warranty. Power adders such as superchargers, turbochargers, nitrous, etc. will void such warranty.
- All prices include using your block and/or crankshaft (In 348ci rebuilds). We can provide blocks or cranks at an additional cost.
Installed Options
- TTP Stage 3 AFR 205cc CNC Heads (Finish Port/Polished at TTP - Assembled with Dual Springs, Titanium Retainers, Spring Seats, Valve Stem Seals): $3000
- TTP Stage 3 AFR 225cc CNC Heads (Finish Port/Polished at TTP - Assembled with Dual Springs, Titanium Retainers, Spring Seats, Valve Stem Seals): $3250
- TTP V.2, V.3, V 3.1, V.4 Equalizer Camshaft: $430
- TTP Hardened Chromoly Pushrods: $105
- Crane Double Roller T/C: $215
- GM LS6 Oil Pump: $90
- SVO 30lb Injectors: $275
- LSX 90mm Intake Manifold: $825 (Add $250 for port matched to your heads OR free port matching if you purchase one of our AFR packages)
- NW 90mm TB for F-Body: $450
- NW 90mm TB for Y-Body: $525 + Core
- SPEC Stage 3 X-Pad: $400
- SPEC Stage 3 F-Pad: $510
- SPEC Steel Billet Flywheel: $225
- SPEC Aluminum Flywheel: $360
TTP Stage I 348ci Magnum Package
- Crower 6.125" Rods
- Diamond Forged Flat Top Piston (-2cc Valve Reliefs - Stock C/R)
- Nitrate/Heat-Treated Stock 3.622 Crankshaft
- Federal Mogul Rod + Main Bearings
- Clevite Cam Bearings
- Diamond Pro Select File-Fit Rings
- ARP Main Stud Kit
- Included is also honing the block to 3.905" bore, cleaning, balancing, and assembly.
- $5649.95 Turn-Key
TTP Stage II 348ci Magnum Package
- Lunati Pro-Billet 6.125" Rods
- ARP Main Stud Kit
- $6199.95 Turn-Key
TTP Stage III 348ci Magnum Package
- Lunati 4340 Forged Crankshaft
- ARP Main Stud Kit
- $6874.95 Turn-Key
TTP 383ci Equalizer Package
- ARP Main Stud Kit
- $7199.95 Turn-Key
TTP 395ci Equalizer Package
- ARP Main Stud Kit
- $7299.95 Turn-Key
TTP 427-448ci Equalizer Package
- ARP Main Stud Kit
- Included is also honing the block to correct bore, stress relief, decking, cleaning, balancing, and assembly.
- We can achieve up to a 4.160" bore for these combinations: 4.125" Bore x 4.000" Stroke = 427ci. 4.125" Bore x 4.125" Stroke = 441ci. 4.160" Bore x 4.125" Stroke = 448ci.
- $12549.95 Turn-Key
Old 12-23-2005, 08:05 AM
TTPMatt's Avatar
t t p
Old 12-23-2005, 12:57 PM
KAOS's Avatar
are these ls2 blocks?
Old 12-28-2005, 02:30 PM
TTPMatt's Avatar
No, these are customer provided or we can provide a core. We have additional pricing for LS2 motors. Basically adds $1050 to the price because of the LS2 Core:
TTP Equalizer LS2 402ci Motor Package:
- Lunati or Callies 4340 Forged Crankshaft
- ARP Main Stud Kit
- Included is also honing the block, cleaning, balancing, and assembly.
- $7299.95 Turn-Key + LS2 Block Core ($1050)
Quick Reply: ** TTP Turn-Key Motor Packages
