<NEW PRODUCT> 8 Channel EGT Data Logger
PRESS RELEASE - 5/31/06
CASPER'S ELECTRONICS, INC.
EGT Logging Module - 8 Channel
This compact design can log up to eight "K" type thermocouple inputs. The eight channels are processed and deliver eight discreet analog 0-4V outputs compatible with the XFI ECU or any other ECU that can process analog inputs.
Additionally, the Module has an RS-232 serial data link which can be routed to any Windows-based laptop. Using "Hyper-Terminal" in your Windows PC, you can log the eight thermocouple inputs and, with internal software, display Deg. C and Deg. F data on all eight channels. The Module also provides a simple "Calibration" mode that matches each thermocouple with the press of a key.
This Logging Module is designed to operate on 10-30VDC and provides 3-color status LED's on each input to assure proper hookup to the thermocouple device.
Unit comes complete with XFI pigtail that interfaces directly into the XFI engine wiring harness. Although can interface with just about any standalone ECU available. Click HERE to view the installation page.
Thermocouples are also available.
Introductory price: $595.00
Discount code: LS1TECH coupon code for 10% off!
Dealer inquiries welcome.
