Mizfit 9 inch GP:
Mizfit 9 inch GP:
Ok here we go I finally got some prices for different setups for you guys. We would need 5 guys to make this happen. You can pick any setup you like. Also as far as shipping goes I will look it up per customer and just pass that on to you.
*Packages require your backing plates
*Add $345.00 for us to supply backing plates
*4-channel add $450.00 and $175.00 for Moser rings
* Option: spool to any package reduce total price by
$150
Option 1: 4 box special – “S” Casting case with choice
for common gear: 3:25, 3:50, 3:70, 3.89, 4:10, 4.30 etc… No Nascar
type gears, upgraded 1350 yoke and 31 spline axles.
Your choice of Tru Trac or Detriot locker,
4 chanel ABS prep by Moser,
Great choice for street and strip use. Our “S”-
Case is built in-house with 1350 yoke. The housing,
31spline axles, torque arm mount are shipped direct
from Moser. Final assembly is required from buyer.
FREE SHIPPING $2375
Option 1+: Same package as above except your choice
for 4 channel ABS, final assembly for full rearend is
finished in-house and will be shipped to customer via
truck freight. Buyer pays Truck Freight.
$2375 + Shipping
Customer will need to ship in their stock ABS rings and backing plates
Option 2: Economy Rear: Utilizes stock case and
housing. Your choice of common gears, 31 spline axles
and upgraded 1350 yoke. Final assembly done in house
$2000 + shipping
This setup is designed for guys who keep breaking
their 10 bolts but don’t intend on having a high
horsepower car.
Mid 10's capablity
Option 3: TRACK DUTY ONLY: Nodular Case with choice of
common gears, 35 spline axles gun drilled, Detriot
Locker, upgraded 1350 yoke. $2650 + shipping
*option 3+: Strange Aluminum Case option adds another
$250
Moser thru bolted case add with 10 bolt pinion support add $475.00
$150
FREE SHIPPING $2375
$2375 + Shipping
$2000 + shipping
horsepower car.
Mid 10's capablity
$250
