RotorsOnline House Disc /or Brembo Disc Package 93-02 F-Body
Old 01-24-2007, 02:39 AM
MikeRotorsOnline's Avatar
Default RotorsOnline House Disc /or Brembo Disc Package 93-02 F-Body
I decided to make a brake package special for LS1Tech. This is a forum only speical. This is for the 1993-2002 F-Body; I put this package together for a street car that sees mild to medium track use. There are two variation of the package listed below.
1st - House package
- 4 (front & rear) of our house discs.
- Front AXXIS Ultimate & Rear AXXIS XBG/Metal Master Brake pads. [98-02 Models]
- Front & Rear AXXIS Ultimate Brake Pads [94-97]
- Front AXXIS AXXIS XBG/Metal Master & Rear AXXIS Ultimate [1993]
- Techna-fit braided stainless steel brake lines. (5-Line kit w/o Traction Control) or (6-Line kit for Traction Control)
- Front & Rear NHT powder-coated brake calipers.
- $850.00 shipped anywhere in the 48 States & Canada.
2nd - Brembo Package
- Everything the same as above except;
- House discs are replaced with Brembo discs. Blank & NIB.
- $925.00 shipped if you would like for me to machine and zinc the Brembo discs.
Please specify which package, year and if your F-body has Traction Control or not. I accpet all major creidt cards and Paypal.
A 60 day warranty is provided to protect for manufactuer defects.
CA Sales Tax applies for orders within California. @ 7.75%
Most of this package is manufactured in North America. Given the exception to my house discs. (Made in Asia).
AXXIS Ultimate & AXXIS XBG are sourced from Australia, Canada, USA!!! & Asia.
Techna-fit brake lines are manufactuered and assembled in Torrance, CA. Their braided stainless-steel line kit can handle up to 3500+psi and is built to MVS-1006 specifications.
FYI. Brembo discs for domestics are sourced from, Italy, Canada (B.P.C) & Mexico.
NHT calipers are assembled by QB Rebuilders in Stockton, CA. QBR maintains ISO 9001:2000 quality standards. Designed to meet & exceed original manufactuer standards/specifications. More info can be found here (http://www.nugeon.com/products.aspx?i=cc)
NHT calipers are powder-coated to order and are available in Red, Black, Silver, and Yellow.
***Important Note*** NHT calipers come with a core redemption coupon (mail-in rebate). With this package it is valued at $200.00 (98-02) & $160.00 (94-97) & $145 (1993). Each NHT box comes with the coupon & directions on how to redeem your coupon; simply send your old, undamaged calipers back to NHT.
Time to process and ship is up to 7 business days.
Let me know if what you think, if you have any questions feel free to ask.
-Mike@RotorsOnline
Last edited by MikeRotorsOnline; 02-05-2007 at 05:50 PM. Reason: Mandatory Info Update
Old 01-25-2007, 06:34 PM
BLASTER's Avatar
You guys doing anything with the trucks. I need brakes badly.
Thanks
Old 01-26-2007, 12:04 AM
99Andrew's Avatar
How about just the "Front & Rear NHT powder-coated brake calipers"?
How much would it be just for the calipers shipped in US?
I have traction control if that makes a difference...
Old 01-26-2007, 03:01 PM
fastmatt98's Avatar
Damn too bad you dont do powder coating in suset orange metallic. I'd be on board with that
Old 01-26-2007, 05:35 PM
Default Sivlerado Brakes
Thanks
I do have brakes for trucks. I can even work out a kit similar to this for you as a special order.
I need to know several things about your truck.
It's a 1500? or 2500? is it 2WD or 4WD? HD? Extend, single or Crew Cab? And does it have 4wheel steering / Quadrasteer?
House disc package looking at $950+ plus shipped.
Let me know what model Silverado you have. And I will give you a finalized quote.
Regards,
-Mike
RotorsOnline
Old 01-26-2007, 05:38 PM
Default NHT Calipers
99Andrew,
The price is $550.00 shipped.
Old 01-26-2007, 05:47 PM
Default I know how you feel...
NHT isn't currently setup to match factory paint codes. They are telling me they are working on it. I will keep you posted once those options are available.
Old 01-26-2007, 05:55 PM
BLASTER's Avatar
Mike,
2000 Silverado 2500 Extended Short Box 4WD 8 lug
Thanks much
Old 01-26-2007, 08:05 PM
99Andrew's Avatar
Originally Posted by MikeRotorsOnline
99Andrew,
Thanks for the fast response!
How does this work:
NHT calipers come with a core redemption coupon (mail-in rebate). With this package it is valued at $200.00. Each NHT box comes with the coupon & directions on how to redeem your coupon; simply send your old, undamaged calipers back to NHT.
So, I pay you the $550.00 and I can get $200.00 back for sending in my cores, correct?
Thanks again!
Old 01-30-2007, 05:52 PM
Mike,
Thanks much
Sorry for the delayed respsone. I got had to file my taxes yesterday.
This is what I can do for you.
House discs with my Dura Sevre Duty Brake Pads & NHT calipers. $800 shipped.
Techna-fit and Earl's both tell me they aren't making line kits for the 2500 due to too much hard line.
NHT is also not doing their core redemption for the 2500 calipers either.
Old 01-30-2007, 05:56 PM
How does this work:
Thanks again!
No Problem.
Yep, thats correct. They are doing this all year on select calipers. Camaro, Mustang, Corvette.....their offer ends on the 12/31/07.
Regards,
-Mike
RotorsOnline
Old 02-01-2007, 12:51 PM
ND4SPD _SS's Avatar
how much for this kit minus the calipers?
1st - House package
Old 02-01-2007, 01:29 PM
1st - House package
For the House packaged with out the Calipers I can do....
$450.00 shipped.
Old 02-04-2007, 01:01 AM
loyolacub68's Avatar
Do you guys price match on the rotors?
Old 02-05-2007, 12:13 PM
Default Yes.
I can. What do you got for me?
Old 02-05-2007, 12:49 PM
pm sent
Old 02-05-2007, 05:41 PM
Default NHT adjustment
I recieved an adjustment from NHT on their core redemption program, this morning.
Some various calipers have been added as well a a few changes in the core redemption.
As far as affecting this post and this brake package, please read the following:
***Core Redemption for the 1994-1997 F-body has been changed to $80.00 per pair. A total of $160.00. And 1993 is valued at $145.00***
Sorry to be the bearer of bad news.
Thanks for reading this.
-Mike
RotorsOnline
Old 02-05-2007, 10:39 PM
99SLOWC5's Avatar
Can you put something together for a C5
Rotors ( brembo )
SS lines
Pads
JEFF
Old 02-06-2007, 03:25 AM
Default C5/Z06 Brake Package
Rotors ( brembo )
SS lines
Pads
JEFF
Sure Can.
I am running the same similar special on another forum.
Go to this thread.
https://ls1tech.com/forums/sponsor-sales-specials/698014-rotorsonline-house-disc-brembo-disc-package-97-04-c5-z06-corvette.html
Last edited by MikeRotorsOnline; 04-17-2007 at 01:10 PM. Reason: Opened another thread for this package. Different information.
Old 02-06-2007, 07:01 AM
99SLOWC5's Avatar
Whats the cost for the brembo blanks without the Calipers, I just purchased some new calipers
JEFF
Quick Reply: RotorsOnline House Disc /or Brembo Disc Package 93-02 F-Body
