Is this a good spot for a ground?
Old 11-03-2008, 10:53 AM
DrewSG's Avatar
Default Is this a good spot for a ground?
In the spare tire well. Is there a way to test whether it's a good ground or something.
Also, does anyone know where I can get these:
I've looked around and can't seem to find them, but I can't hook my tweeters to my crossover with them. It's a 2.8mm male blade connector.
Old 11-03-2008, 12:31 PM
2FAST4U's Avatar
No.
Are cars are unibody cars. So The floor board is better. As your spot is tac welded on.
And that connector is easy to find everwhere
Old 11-03-2008, 09:53 PM
blackbyrd's Avatar
i used where the seatbelt spool for the rear seats. ground the paint off and used the bolt taht was there
Old 11-03-2008, 10:41 PM
CR71's Avatar
I put my ground on the bolt that holds down the cd changer, its worked fine so far.
Old 11-04-2008, 12:55 AM
Engine_HP's Avatar
looks good to me
Old 11-04-2008, 12:05 PM
OutKlast's Avatar
Doesn't look too bad but there may be a better location.
Old 11-06-2008, 10:09 PM
gnasty1521's Avatar
I think the seatbelt bolt is by far the best. I saw one the other day that had ) guage there. I tested it with my multimeter to the floor board and it had perfect continuity. So Seatbelt bolt is good.
Old 11-07-2008, 08:17 AM
samson_420's Avatar
Same here, I just scuffed up the are 1st.
Old 11-07-2008, 08:29 AM
gnasty1521's Avatar
Deff make sure you do that. The first stereo I had the amp blew up from having ground then not then it arc'd and burned my connector area up.
oh and bolt it down tight NO MOVEMENT!!!
